spud69
posted on 29/6/09 at 10:16 AM |
Inlet and exhaust manifold
Can anybody recommend me a fabricator in the North East for exhaust and inlet manifolds please,
I currently have home made manifolds for my 2.0l zetec on bike carbs and they need doing properly as they are restricting the flow quite a bit.
After this is there much improvement to be made by adding fast road cams to the engine.
Thanks...Andy
Guinness
posted on 29/6/09 at 10:20 AM |
AAS in Scotswood did my exhaust.
http://www.aas-exhausts.co.uk/
Not sure if they do inlet manifolds. Failing that Bogg Bros in Malton aren't a million miles away?
http://www.boggbros.co.uk/contact.html
Mike
posted on 29/6/09 at 10:38 AM |
As above I have a super exhaust from AAS.
With a home made inlet for bike carbs which are big enough I had the carbs set up at Bogg Brothers. I'll be going down again to get them set up
since I changed from 1.8 to 2.0 and will be asking about a cam change.
I understand your homemade exhaust may be restrictive but the inlet?
I can pop down and show you mine if you want?
[Edited on 29/6/09 by coozer]
