Author: Subject: MIG welding aluminium alloy
posted on 30/6/09 at 08:28 PM Reply With Quote
I need to change the outlet position of a crossflow aluminium alloy thermostat housing. I've sawn the top away from the base and need a 10 mm spacer in order to clear a nut.
Plan is to cut a 10 mm wide strip from 3 mm aluminium sheet, roll it to a tube and MIG weld it in between the two pieces.
What are my chances of succeeding?
Will MIG welding the housing cause problem due to incompatible metals?
Or am I better off looking to get it TIG welded?
matt_gsxr
posted on 30/6/09 at 08:32 PM Reply With Quote
nice deraileur
whitestu
posted on 30/6/09 at 08:34 PM Reply With Quote
Unless you are a really good welder I'd say your chances of success are low. I had a go and got nowhere with it.
Stu
flak monkey
posted on 30/6/09 at 08:39 PM Reply With Quote
http://www.mig-welding.co.uk/aluminium-welding.htm
Its not too difficult on thick stuff, but very tricky on thin sheet.
Sera
http://www.motosera.com
posted on 30/6/09 at 08:58 PM Reply With Quote
Many years ago when I was still at school doing metalwork I made a shooting stick , the top part of which I cast using aluminium . Easy to model the part in wax before making the mould in sand (may have been a special sand?)
posted on 30/6/09 at 09:03 PM Reply With Quote
IMHO tack welding ali is okay, anything more than that using MIG is a bit tricky. But I think a combination of MIG for tacking followed by some Technoweld (bizarely for strength) is quite a good combo... That's what I'm using for my airbox anyway....
MkII
posted on 30/6/09 at 09:26 PM Reply With Quote
quote;
somewhere between "slim and none at all"
i use mig for 6/8mm ally plate but for thin stuff allways tig.I repaire my crossflow thermostat housing with tig when the small air bleed outlet got snapped off. m.
ashg
posted on 30/6/09 at 11:25 PM Reply With Quote
tig it. its the only sensible way.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Sam
posted on 1/7/09 at 07:29 AM Reply With Quote
Unless everything with your MIG set is spot on it is likely you will fail miserably. i.e. drive rolls good condition preferable knurled ali rolls with correct pressure. teflon liner, short torch, clean contact tip and correct setting required. The most common problem is bird nests in the wire drive. TIG is the way forward !!
posted on 1/7/09 at 07:55 AM Reply With Quote
I've MIG welded alloy many years back, the results were not exactly pretty but it was strong enough. I've even welded a holed piston on a field bike!
It does take a lot of messing around to set the welder up for alloy wire though and you need a decent (pref. teflon) liner in the torch.
iank
posted on 1/7/09 at 08:07 AM Reply With Quote
Best to use a gun mounted reel for aluminium.
http://www.youtube.com/watch?v=V_MiGrL9350
But since you need a bottle of pure argon it's probably cheaper to get someone to TIG it for you.
Anonymous
GrumpyOne
posted on 1/7/09 at 08:43 AM Reply With Quote
Silica sand, not readily available in small quantities also expensive, but you can use it many times.
My wife is very understanding, she understands that if I am in the garage I am not in the house annoying her.
davie h
posted on 1/7/09 at 08:49 AM Reply With Quote
i attempted to shorten a mondeo zetec sump by ally mig welding gave up and bought a escort sump.
Davie
http://www.flickr.com/photos/24179682@N04/?saved=1
