Author: Subject: WTD someone to raise my engine
blueskate
posted on 6/7/09 at 03:44 PM Reply With Quote
Hi all,
I'm looking for someone in the Essex area that can do some fabricating work for me. Basically i have an MK indy r1 but the engine sits way to low. I plan to get some spacers to bring the engine cradle up 20mm but there are two brace bars connected to the lower chassis rail from the engine that would need cutting, lengthening and re-welding at a different angle.
Any suggestions? I spoke to my local garage but they're not keen.
Semper Paratus!
NS Dev
posted on 6/7/09 at 04:05 PM Reply With Quote
Hi, we can do it but we are a long way away! (leicestershire)
if you get really stuck, u2u me
barbarianbeast
posted on 6/7/09 at 04:07 PM Reply With Quote
i am in the same boat!! the engines are sat very low.
my sump is stuck 60mm below the car and i was thinking of raising it 60mm for a flat floor,
the spacers cant be that hard, just some aly round bar and a pillar drill, it those bottom mounts that make it harder.
NS Dev
posted on 6/7/09 at 04:16 PM Reply With Quote
again, let me know if you want, we can do it for you, leics area, just down the road from mallory park
stuart_g
posted on 6/7/09 at 08:55 PM Reply With Quote
907 is your man, he is in Essex and can fabricate just about everything, not too bad at welding either give him a U2U.
blueskate
posted on 7/7/09 at 11:21 AM Reply With Quote
Thanks Stuart_G i'll drop him a line
Semper Paratus!
