bob
posted on 8/7/09 at 04:35 PM |
Indy throttle pedal connection
OK lads if possible show me yours
I've never been happy with the throttle cable set up using the floor up Indy pedal,i've had various set ups and just want to see what
others have done.
Stuart_B
posted on 8/7/09 at 07:32 PM |
this is what i have done:
![](/galpreviews/P6240001.jpg) ![1](/gallery/P6240001.jpg) 1
stuart
bob
posted on 8/7/09 at 07:52 PM |
Got it in one cheers stuart
I am presuming the U shape bracket where the pivot bolts is the back stop, i'm thinking this is my problem.
I will be really peeved if that part comes with the original kit and i didnt get it
Stuart_B
posted on 8/7/09 at 07:58 PM |
the u shaped bracket, i amde to stop teh pedals coming down to far, they did not come in the kit, just bent in 2mm steel, the bolt is a m6, with a
hold drilled through it with a washer, adn a nut and then the other side is a nylock, not done up tight just enough to get the nylock to grab.
stuart
bob
posted on 8/7/09 at 10:45 PM |
cheers stuart
eccsmk
posted on 8/7/09 at 10:48 PM |
stuart
mine is the same as this only i used a small one of
these to hold the cable on
HTH
[Edited on 8/7/09 by eccsmk]
Dan
posted on 16/7/09 at 09:48 AM |
In stead of the effort to make a bracket why not just put a bolt through the two holes below the pedal pivot holes looks way neater.
MautoK
posted on 17/7/09 at 03:58 PM |
Better late than never!
![](/galpreviews/P1040033.JPG) ![Throttle pedal](/gallery/P1040033.JPG) Throttle pedal
It's the MK pedal with the end of the Sierra pedal welded on, so that I could use the standard cable.
John.
bob
posted on 17/7/09 at 07:23 PM |
Big thanks for all the replies, i have made a new stop which seems to work fine now.
I am now thinking the pedal would work/react a lot better if it was a lot lighter,the original pedal weighs 180g which doesnt seem a lot but does make
a difference.
I'm planning to make my own sprung pedal in the future using the same axis as on the chassis,i'll post up pics when complete. (dont hold
your breath i'm not exactly quick)
Stuart_B
posted on 18/7/09 at 09:04 AM |
nice one bob
