Author: Subject: Fiat Seicento aircon
wicket
posted on 13/7/09 at 11:54 AM Reply With Quote
I recently had the unit serviced and now when it has been used it drips ice cold water into the foot well, it can be either side. I believe the drain pipe is blocked anybody give me clue as to were the pipe is?
Omni
posted on 13/7/09 at 12:17 PM Reply With Quote
First thing I would do is take it back!
O
serieslandy
posted on 13/7/09 at 12:30 PM Reply With Quote
Our fiesta does this but only into the passanger foot well. So any advice would be good.
thefreak
posted on 13/7/09 at 02:38 PM Reply With Quote
Dont know how similar the setups are to the FTO, but I know this is common with them and it indicates the Heater Matrix is fubar'd
mark chandler
posted on 13/7/09 at 03:00 PM Reply With Quote
crawl under the car, there will be a little drain hose from the heater/cooler box directly under it.
Just push something soft like a cable tie up it, then move your head before you get drenched.
On one car I had there was so much crude that I had to pull off the heater air inlet and hose off the matrix, right pain but no more horrible smells
Paul (Notts)
posted on 13/7/09 at 05:16 PM Reply With Quote
as above - a little pipe hanging down directly under the centre consoule on a fiesta.
