New Topic New Reply
Author: Subject: Nice simple explaination of Ackerman angles
Benonymous
posted on 3/8/09 at 04:04 AM Reply With Quote
This is an RC car web site but I found the diagrams and animations really easy to understand. I especially like the fact that the writer has gone to the trouble of illustrating how to calculate Ackerman and a toe-in, toe-out version.
http://www.rctek.com/technical/handling/ackerman_steering_principle.html
907
posted on 3/8/09 at 06:54 AM Reply With Quote
My first recollection of Ackerman was in 1965, when I was 10.
I had an Airfix slot car set for Christmas as it was cheaper than Scalextric. (Times were hard )
A Vanwall and a shark nose Ferrari.
It said on the box "Full Ackerman Steering" and I had to get my older brother to explain it to me.
Paul G
LBMEFM
posted on 3/8/09 at 07:11 AM Reply With Quote
and.........................................
posted on 3/8/09 at 07:39 AM Reply With Quote
The bit no website or book will tell you is true Ackerman geometry can't be applied to rack and pinion steering.
Classical Ackerman only works where the steering uses a centre track rod --- ie a lorry style beam axle or a 1950's style suspension with a steering box and idler arm.
To get an ackerman effect ( toe-out on turns ) on a book style Locost style chassis the steering rack positioning of the donor Ford should be copied, that is the centre line of the steering rack set a few inches to the rear of an imaginary line joining the centres of the outer track rod ends.
[Edited on 3/8/09 by britishtrident]
New Topic New Reply
