chrisunwin
| posted on 7/8/09 at 04:44 PM |
Alfa Romeo Transaxle
Hi
Has anyone ever used an Alfa Romeo Transaxle at the back of their car?
I know this means widening the rear a bit where the diff would go.
Advantages would be inboard brakes, LSD and possibly better weight distribution.
Regards
Chris
| posted on 7/8/09 at 06:33 PM |
Some Romanian blokes did one a few years back and they had to raise the rear floor and seats to clear it.
cfv23844
posted on 15/8/09 at 08:51 PM |
alfa tranaxle
I'm finishing my Alfa/7. The donor car was the 116 Sprint Veloce with transaxle. It is built on a McSorley 442 chassis. With the flywheel up
front there is more room for my big feet and self made seats are necessary for a 6'2"x205 lb body. A tight fit but no higher than usual
and with generous soft foam a comfortable snug fit.
TheGecko
| posted on 16/8/09 at 12:25 AM |
There's one at http://diligentdesign.ca/seven/ which is very nicely finished (if not quite to my
personal taste) but it is apparent that the transaxle crowds the cabin a bit.
Benonymous
| posted on 18/8/09 at 05:44 AM |
Looks like a very uncomfortable setup. The gearbox will get hot and I don't think the weight distribution will benefit greatly. In fact
it's moved a significant weight nearer to the rear and away from the centre of the car. The finish of the whole thing looks superb though.
andyps
| posted on 20/8/09 at 01:23 PM |
I am sure there would be some issues with doing so, but why not extend the wheelbase so the transaxle is slightly behind the seats rather than between
them?
philipcurtis100
| posted on 20/8/09 at 05:47 PM |
dont like the wooden floor
chrisunwin
| posted on 23/8/09 at 11:16 AM |
Thanks for the info. Having seen an Alfa transaxle in the flesh now, I think I will go the conventional route, and use a Sierra diff. Love the
pictures of the Alfa.
Regards
Chris
| posted on 23/8/09 at 12:40 PM |
If you could replace the clutch mechanism with a concentric slave you'd save a lot of room on the right hand side. I have visions of a
passenger getting their thigh well and truly pinched by the arrangement in the car above.
andkilde
| posted on 24/8/09 at 12:33 PM |
quote: I have visions of a passenger getting their thigh well and truly pinched ...
Well, it is an Italian car after all
| posted on 24/8/09 at 01:05 PM |
