Author: Subject: MK replacement wishbone setup. (wozsher's)
Nosbod
posted on 10/8/09 at 06:53 AM Reply With Quote
I have lovely new pair of Wozsher's top wishbones coming for my Indy this week and am not sure of where to set the "toe" to give it the necessary self-centering for my SVA re-test on Friday.
Is a little bit out toe-out still necessary to get it through the test? Also should i put "normal" pressure in the tyres (i.e. 16-18psi) or over inflate a tad?
I did try searching for this myself but after trawling through the mountain of self-centering topics for over an hour with no joy I figured a quick new post was in order.
Chris.
[Edited on 10/8/09 by Nosbod]
mad-butcher
posted on 10/8/09 at 07:29 AM Reply With Quote
Hi Chris
If you've ordered the fully adjustable rose jointed wishbones you should have no problems really as the top ball joint pickup has been moved back 15mm to give the neccesary castor angle for self centering, but belt and braces says a little bit of toe out and about 30 psi in the front tyres
tony
Nosbod
posted on 11/8/09 at 06:04 AM Reply With Quote
Thanks Tony.
tul214
posted on 11/8/09 at 02:10 PM Reply With Quote
Good luck for Friday Chris.
Mark
1.6 Raw Super6 sold
