ned
posted on 22/3/04 at 11:48 AM |
Do I really need w1 + w2?
I spent the weekend finishing the mods to my chassis to accept the dedion axle that i collected on friday.
I have also fully welded in my rollbar which is a normall straight sided hoop from the mounting plates, with a diagonal and 2 long backstays that go
to the bottom rear corners of the chassis where it is fully welded to 3mm plate that is fully welded to the sq and curved tubes in the corners. i
really should have taken a pic, but my camera was out of batteries
I have all of the other 'book' tubes on my rear end, but do I really need w1 w2, as the rollbar must be far stronger for the strength of
the chassis?
thanks all,
Ned.
ps page 38 of jim mcsorleys pdf plans shows the tubes I'm on about for those that don't have their bible handy..
beware, I've got yellow skin
PioneerX
posted on 22/3/04 at 12:03 PM |
Ned,
I'm no expert but to me it looks like the effect would just cause a change in the angle the load is transmitted in. Other than the load from the
fuel tank and rear body work I cant think of anything else these bars would be supporting other than a little bit of torsional stiff ness due to there
angle.
Basically as far as I can see the load would just transmit through the roll bar rather than the O tube, the rear bulkhead tube. As long as the roll
bar stays & bar itself are of greater strength that tube O I can see any adverse effect.
As said, I'm no expert.
Simon.
[Edited on 22/3/04 by PioneerX]
Crazy Jay
posted on 22/3/04 at 04:47 PM |
Ned, settle an argument, wat age are u? My mate thinks ur old and i think u are young. Please let me know so i can claim my tenner! Cheers Ned,
goodluck wit ur car
ned
posted on 22/3/04 at 05:00 PM |
looks like you're owed a tenner.
Ned.
Mark Allanson
posted on 22/3/04 at 07:57 PM |
I think this area of the car is not well designed, all the loads from the rear suspension are directed up into the 4" square plate which is only
secured on one side to the transverse upper tube of the seat back panel. The X and W tubes must help to a certain degree, and a triangular plate fixed
to the top of the X tube may help a little more. My roll bar will help a bit more as per Ned's layout.
Any comments?
Crazy Jay
posted on 22/3/04 at 09:39 PM |
Agree totally!
M@Triton
posted on 22/3/04 at 10:12 PM |
Going the de-dion route has the shock bracket in a different location....well it does on the GTS jobbie....it is tied into the diagonal going into
boot,the 4"plate then gusseted with all this linked tickty boo with 16swg rhs....nowt like book but same if that makes sense!!
Mark Allanson
posted on 22/3/04 at 10:20 PM |
Got any shots?
M@Triton
posted on 22/3/04 at 10:26 PM |
I will take some tomorrow and if i can make it work post them in here.
Mark
ned
posted on 23/3/04 at 09:39 AM |
Mark,
look forward to seeing the piccies, my axle is nearly ready to go on now and was wondering about where to mount my shocks.
One question i did have Mark(triton) is that my axle doesn't have the reinforcement plate bit in the centre where the 2 halves of the dedion
tubes are welded. i see from others pics that they have. is there any reason for this?
thanks,
Ned.
cymtriks
posted on 25/3/04 at 09:07 PM |
The suspension top plate should be panelled in so that loads are spread out into tubes O/W1/W2. Don't rely on just welding the suspension top
plate to tube O. Check the picture on page 62 of the book. Loads put into W1/W2 find their way back into the chassis sides via tubes RU1/RU2 so the W
tubes do do some real work in the chassis.
jbmcsorley
posted on 30/3/04 at 07:40 PM |
w1, w2
I always figured that w1 & w2 were in tension and didn't help the roll bar at all. If you think about a full tank of petrol (8 gallons?)
hanging over RU1/2, then W1/2 are in tension to keep the boot from sagging. This would explain why Ron chose 3/4" tubing for W1/2... you
don't need much cross section when pulling on steel.
Jim M.
I love speed :-P
posted on 30/3/04 at 07:54 PM |
Jim M.
well what difference would it make if i made my w's out of the 25mm, as i have some spear instead of buying some 19mm x19mm?
Thanks 4 ur time
phil m
Don't Steal
The Government doesn’t like the competition
posted on 30/3/04 at 07:58 PM |
extra weight only. You can work out how much, probably around 25% for comparable lengths. When i did the equivilent (sp?) bit on my car, i used mostly
19mm 18 or 20g tubes, as it has next to no real structural function (on mine at least...).
Mark Allanson
posted on 30/3/04 at 08:38 PM |
I changed my mind over my nice simple hoop bolted rollbar, because of this. I wanted to...
1, Increase the rear crash resistance of the car and protect the fuel tank.
2, I needed somewhere to put my upper seat belt mounts, so needed triangulation for these
3, I did not believe that the upper shock mounts wount not fatigue fracture after a few thousand mile on Cornish bumpy roads
