Slater
posted on 18/8/09 at 02:10 PM |
sierra wheel hub hole diameter
hello
Can some one who has a sierra wheel measure the ID of the hole in the middle for me please? I have to undo my rear hub nuts (to change the bearing),
my socket is 60mm OD, so I want to check if my impact socket will fit inside.
My sierra build wheels have been borrowed by weescottishmatt, so I don't want a wasted trip to collect them if the hole is too small.
Is there another way to undo the hub nuts? I think the only way is to have the car on the ground with the wheels on. The hole on my alloys is too
small for the socket, that's why I think I need the build wheels. Or maybe a small OD socket??
handyandy
posted on 18/8/09 at 02:19 PM |
just measured a standard steel sierra wheel & the inside diameter is 63mm.
hope that helps
andy
handyandy
posted on 18/8/09 at 02:24 PM |
scratch that, sorry i measured the out side of the hole on the lip,
the internal measurement is 61.5 mm spot on.
sorry for incorrect first reply
andy
[Edited on 18/8/09 by handyandy]
wescottishmatt
posted on 18/8/09 at 04:18 PM |
I've checked the wheels and they are biggerthan the 60mm. I would say as above maybe a little bigger on these ones.
Matt
