Author: Subject: Megasquirt throttle enrichment's
madteg
posted on 18/8/09 at 04:57 PM Reply With Quote
How do you set them up. ( HELP ).
clairetoo
posted on 18/8/09 at 05:43 PM Reply With Quote
I didnt have a lot of success with the normal TPS activated enrichment , so mine is set to RPM based accell - and its a pleasure to drive , as well as being very easy to set up .
Its cuz I is blond , innit
Claire xx
Will weld for food......
mark chandler
posted on 18/8/09 at 07:51 PM Reply With Quote
If your fuel map is very close then you will hardly need them as the rpm and MAP signal will deliver the correct amount of fuel.
Best to turn all enrichments off, drive using gentle throttle applications in all revs and loads with a wideband sensor and autotune enabled, or log and feed in to megalog viewer.
But first make sure the reference points are grouped around the most used points so log and stat in excel.
After this I found all I needed to do was blip the throttle and add enrichments so the engine responded crisply without flat spots on instant opening.
Regards Mark
v8james
posted on 19/8/09 at 09:23 AM Reply With Quote
After i got the fuel bins tuned using Megalog viewer, with the enrichments turned off. I set the enrichments to the following.
This is for a 2.0L Zetec.
regards
JamesImage deleted by owner
