Author: Subject: regarding dampers
ghuncha
posted on 8/9/09 at 06:44 PM Reply With Quote
regarding dampers
hello all
well the current status of my build is that i have fabricated a book chassis, the uprights i am using are of toyota liteace(only ones available to me), the engine is toyota 4age 20v. rear is a live axle.
now i have to get some dampers to finish up my suspension. a froind of myne is coming form uk so i have an opertunity to get the dampers.
now which one should i get,
linky
was considering these, are they any good, and what spring rate should i get, considering it will be a car engined, secondly the open and close length.
need to make decision fast, as my friend will be flying on 20th of this month
regards
ghuncha
posted on 8/9/09 at 06:46 PM Reply With Quote
further more any idea about the weight of 4 dampers with springs, as this is the most important factor when you are traveling by air
blakep82
posted on 8/9/09 at 06:48 PM Reply With Quote
Gaz shocks are good if they weren't, these lot wouldn't use them
don't know about spring weights. but that looks a good price to me
________________________
speedyxjs
posted on 8/9/09 at 06:59 PM Reply With Quote
They are cheap
I think i will be getting my replacements there!
ghuncha
posted on 8/9/09 at 07:01 PM Reply With Quote
ok so the price and brand is ok
what about the open and close length and the spring rate
Canada EH!
I have Lotus 7 steel body GAZ shocks on the front of a 4 AGE powered book chassis,(Cortina uprights) and ali GAZ on the rear.
The steel ones are quite heavy (bought off ebay) the rears are very light.
They come nicely boxed of a size that would easily fit in a carry on bag.
If doing it again I would go for ali shocks both ends,
ghuncha
posted on 8/9/09 at 07:05 PM Reply With Quote
so are these allys? there is very little detail in the link, i think i will have to call them tomorrow.
ghuncha
posted on 8/9/09 at 07:06 PM Reply With Quote
btw what spring rates and damper size(open and close) are you running?
procomp
posted on 9/9/09 at 07:18 AM Reply With Quote
Hi
For best quality and valving use PROTECH. They come as standard in alloy unlike the GAZ or AVO.
For open lengths the rear will want to be 13" thats the standard fitment on all BOOK dimension rear ends. This gives the chassis a ground clearance of around 4 1/2" at the rear. If you require a higher ride height then use a 14" open length.
The front maybe slightly different using your uprights but the standard fitment for the front is 12 1/2". this give a ride height of around 4" at the front. again if you need to go higher then use a 13" this will allow a ride height of up to 5" under the front chassis.
For springs the rear will want to be 140LB if the car is driver only use and 160LB if mainly driver and passenger use. For the front try 300LB as a starting point.
If you are really wanting to use GAZ then buy them from Dampetech. They will specify valving to suit your application. Buying from any supplier who just keeps them on the shelf means they have general valving settings in them to cover many applications. IE not suitable for lightweight cars such as Kitcars.
Cheers Matt
James
posted on 9/9/09 at 08:48 AM Reply With Quote
The Protech as mentioned by Matt really are lovely bits of kit.
I bought mine from MK, but I'm sure you can get them elsewhere.
James
ghuncha
posted on 9/9/09 at 08:53 AM Reply With Quote
well now i feel i dont know anything about dampers...
as far as i thought vavling can be adjusted but the small knob.. :S
procomp
posted on 9/9/09 at 09:15 AM Reply With Quote
Hi
The small knob dose allow adjustment of the damping range. However the dampers that are generally supplied have a damping range that is more suited to a much heavier car Ie light saloon/ hatchback. And usually have a ratio of bump - rebound that is too high for applications such as 500-600Kg weight kitcars Etc.
By going through suppliers who are or employ damper engineers they can sort out a specification that will be more suited to your application and tell the damper manufacturers what specifications to build to. Hence suggesting Protech direct or Procomp ( myself ) for protechs. Or for GAZ use dampertech.
The majority of kitcars built are suffering with poor ride quality / handling due to the wrong specification of damper being fitted to there cars. Hence they are running on very low settings to get better results.
Cheers Matt
ghuncha
posted on 9/9/09 at 09:31 AM Reply With Quote
matt, you have a message
