richwill
posted on 14/9/09 at 10:54 AM |
Cleaning oil spill
What do people use to clean up oil spills on the garage floor . I spilt oil from the filter on the nice clean concrete floor and would like to try and
clean up the mess.
blakep82
posted on 14/9/09 at 10:56 AM |
cement dust, cat litter box stuff, saw dust, all kinds of stuff really
________________________
mistergrumpy
posted on 14/9/09 at 10:58 AM |
Cement dust from the floor, newspaper, sand whatever's to hand as Blake says.
Mr Whippy
posted on 14/9/09 at 11:02 AM |
got a fluffy cat and a pole?
blakep82
posted on 14/9/09 at 11:06 AM |
don't think you need to hire polish people to clean up an oil spill...
tegwin
posted on 14/9/09 at 11:09 AM |
Blow torch!
www.verticalhorizonsmedia.tv
nib1980
posted on 14/9/09 at 11:16 AM |
cat litter works well for me.
i also have a carpet in the garage, so i just cut the section out and replace with another from the scrap heap
posted on 14/9/09 at 11:34 AM |
Kitty litter is ok as long as you don't try to use the pine wood based stuff, "Fullers earth" is what you need. However, cement is
a lot more effective IME.
posted on 14/9/09 at 11:46 AM |
I used some sharp sand (hand it to hand in the garage). Soaked up the oil nicely. Though I suspect cement is best as that's what they use on
race tracks...
hobbsy
posted on 14/9/09 at 12:05 PM |
If you paint your garage floor first then it pretty much just wipes up with old rags and doesn't soak in.
posted on 14/9/09 at 12:06 PM |
Use some washing detergent neat to get rid of the stain after you clean up if you are bothered about it. Scrub it in then rinse it off but it will
fade eventually or get more added to it.
designer
posted on 14/9/09 at 01:45 PM |
Spred kitty litter over the stain and rub over with a brick.
It grinds the litter and absords the oil.
