Author: Subject: westfield rear upright + sierra calipers
m8kwr
posted on 20/9/09 at 07:47 PM Reply With Quote
I have some westfield rear uprights, brought some sierra calipers, and solid disc.
Just got all parts together, and put them in place, so see how it looks etc.
Things look a bit strange, as the caliper does not go anywhere near the bolt holes on the upright.
Do i need to use a spacer or something? Or should it just all fit together.
Are there different rear calipers? If so, which one should I of brought.
I keep buying wrong parts at the moment, and its doing my head in......
fesycresy
posted on 20/9/09 at 07:52 PM Reply With Quote
You can use either Sierra or Golf rear calipers, depending on which upright you have asked for.
Looks like you've bought a Golf caliper one.
martin1973
posted on 20/9/09 at 08:38 PM Reply With Quote
you will be needing escort front discs not sierra ones.
martin
spaximus
posted on 21/9/09 at 07:33 AM Reply With Quote
I suspect you will be missing the carriers off the calipers. Without them the calipers are no where near.
m8kwr
posted on 21/9/09 at 08:03 AM Reply With Quote
I took these photo last night, just showing the carrier over the disc, and the gap that i am faced with.
martin1973
posted on 21/9/09 at 08:43 AM Reply With Quote
yes had the same thing when building my westy
you need escort mk 3/4/5 front discs. they have a deeper dish.
martin
m8kwr
posted on 21/9/09 at 09:03 AM Reply With Quote
Brilliant,,,, just the wrong disc... not so bad...
m8kwr
posted on 21/9/09 at 10:00 AM Reply With Quote
Does anyone know what model of escort, i should be looking at.
From what i can see from images, the 1.6/1.8 diesel ones seem to be correct??
phelpsa
posted on 21/9/09 at 10:29 AM Reply With Quote
The discs you want have an overall height of 58.2mm, those ones are 42.1mm. I bought the wrong ones too but couldnt work out what car i actually needed them off! In the end I went to the motorfactors and they could look up the specs on the discs and we found the right ones.
EDIT: i've just realised those are the discs I sold to you having replaced them with the discs that you actually want! Oops!
EDIT 2: Do the discs appear to be too big? If those are the ones I sold you then they're XR4x4 rear discs and are also 13mm larger diameter than the Escort fronts.
[Edited on 21-9-09 by phelpsa]
CNHSS1
posted on 22/8/13 at 02:26 PM Reply With Quote
disc code KBD 003 or NBD003 ford and westfield. 240mm solid, with greater offset than those you pictured
[Edited on 22/8/13 by CNHSS1]
