adrianreeve
| posted on 25/9/09 at 08:55 AM |
For Sale - JAW Wideband Lambda Controller and sensor.
Due to a change of plans, I've got a fully built and tested, but never used, JAW Controller and display for sale - £40 posted.
I've also got an almost new lambda sensor to suit the above or an LC1 etc, but the plug has been cut off, so you'll need to source one
from somewhere - £20 posted
Adrian
[Edited on 25/9/09 by adrianreeve]
MakeEverything
| posted on 25/9/09 at 10:02 AM |
Is it a wideband lambda? Ill have it if it is...
Kindest Regards,
Richard.
adrianreeve
| posted on 25/9/09 at 10:53 AM |
It is wideband -- are you after the sensor, controller or both?
Adrian
MakeEverything
| posted on 25/9/09 at 11:21 AM |
Adrian
Just the sensor, as im running Megasquirt which will give me the readings i need.
Kindest Regards,
Richard.
adrianreeve
| posted on 25/9/09 at 11:48 AM |
Which version of megasquirt are you running? I thought that you needed a wideband controller to feed info to the megasquirt, wasn't aware you
could directly connect the sensor.
I stand to be corrected of course!
Adrian
adrianreeve
| posted on 25/9/09 at 09:55 PM |
Bump
| posted on 26/9/09 at 12:09 PM |
Adrian
You need the controller as well, unless you already have one.
adrianreeve
| posted on 28/9/09 at 12:32 PM |
bump
adrianreeve
| posted on 9/10/09 at 03:47 PM |
Both still available!
Antnicuk
| posted on 9/10/09 at 06:33 PM |
i'm not very clued up these things, i am looking for a gauge, preferable round but not vital, that will display my A/F ratios accurately. Is
that what you are selling?
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
Antnicuk
| posted on 9/10/09 at 06:35 PM |
any pictures would be useful also.
[Edited on 9-10-09 by Antnicuk]
adrianreeve
| posted on 9/10/09 at 07:13 PM |
That is what it is yes, but it's in a digital display, a bit like a big calculator! It needs putting in a housing, and the sensor needs a plug
and socket from a scrap car, but its around a third of the price of a complete LC1 with guage, so if you don't mind a bit of work, it's a
bargain!
Same as pic in link below (click on see original image)
http://images.google.co.uk/imgres?imgurl=http://www.14point7.com/JAW/JAW_1_03_with_Display.jpg&imgrefurl=http://forums.fourtitude.com/zerothread%3
Fid%3D3346056&usg=__le0ptZzqip0Hmu7qebnVS7AZ_jg=&h=1413&w=1335&sz=360&hl=en&start=3&tbnid=tMxKzeWpdhNsuM:&tbnh=150&
;tbnw=142&prev=/images%3Fq%3Djaw%2Bcontroller%26gbv%3D2%26hl%3Den
Adrian
[Edited on 9/10/09 by adrianreeve]
Antnicuk
| posted on 9/10/09 at 07:30 PM |
thanks for that, so does the lambda sensor plug into the com port on the bigger board or is there some kind conversion for it?
Does the bigger board come in anykind of box or is it exactly as the picture?
EDIT
Just seen the blue connector block.
I assume the lambda wires to that?
Does the com port connect it to a laptop? I am using a microtec ecu which also has a com port, how does it link in with that?
Sorry for all the questions
adrianreeve
| posted on 10/10/09 at 07:59 PM |
Now Sold!
