Author: Subject: possible donor
kennyrayandersen
posted on 25/9/09 at 11:34 AM Reply With Quote
possible donor
How about this for an engine and transmission donor? I'm not sure how you would integrate the IRS, but the engine and tranny look promising.
http://cgi.ebay.com/ebaymotors/JDM-3SGE-Beams-DUAL-VVTi-6-Speed-RWD-Engine-Swap-3S-GE_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem5883545689Q QitemZ380160464521QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Davey D
posted on 25/9/09 at 11:35 AM Reply With Quote
listing been removed?
blakep82
posted on 25/9/09 at 11:38 AM Reply With Quote
nope, bad link
try this
________________________
nz_climber
posted on 25/9/09 at 09:29 PM Reply With Quote
Thats what I have going into my car, with dry sump. Great engine, pretty tall thou, and gearbox is wide through the bellhousing area.
Check out my build for pictures and ideas, and send me a message if you have any questions..
http://wwww.aarons7.wordpress.com/
http://aarons7.wordpress.com
kennyrayandersen
posted on 27/9/09 at 06:09 AM Reply With Quote
Boy! that does look ling a lot of engine stuffed in there. Seems quite a bit taller than the 4AGE. Your install looks very nice though. I'll check out your links.
Sorry about the link -- sometimes they paste funny, and you use the crappy tiny URLs they often times go to crap, or so it seems. I wonder a little about getting it through any emissions though, since it wasn't originally imported into the States.
kennyrayandersen
posted on 27/9/09 at 07:13 AM Reply With Quote
Nice pics -- what is the IRS setup out of?
col
posted on 27/9/09 at 04:59 PM Reply With Quote
God that looks a beast, Id love to see that runnin,any idea of its weight?
nz_climber
posted on 27/9/09 at 07:15 PM Reply With Quote
IRS is just a standard sierra set up, with double wishbones. Yeah the engine is tall (mainly in the head area and intake plenum), not sure of the exact weight, but its about the same (if not lighter) as a Nissan SR20 (which is an alloy block) and shouldn't be too much more than a 1.8 Mx5 and 6speed set up.. (same gearbox with different housings)
Total car weight will be around 600kg mark
Not sure about emissions in the US (there is not any specific rules here in NZ for custom built cars yet)
Finding wiring diagrams proved a problem to start with, but have tracked down enough info to piece it all together, so can provide that sort of info when and if you need it.
Dry sump was put on as the alloy section of sump around the bottom was very wide and also pretty deep, so the new sump means I can fit the whole lot under the bonnet without any scoops/bulges, also gives good grand clearance.
nz_climber
posted on 27/9/09 at 08:21 PM Reply With Quote
Also alot of information about the engine, and putting it into Fraser Clubman by an aussie Bill Sherwood, great reading and pictures
http://www.billzilla.org/fraser.htm
