franky
| posted on 27/9/09 at 09:31 PM |
cheapest place to buy silicone hose?
Where's the best/cheapest place to get some? Mating my zx12 engine to the polo rad is going to require 4 90deg bends/ 2 t-pieces/6 hose joints,
2.5 m of straights
So need to find somewhere cheap!
cd.thomson
| posted on 27/9/09 at 09:43 PM |
why not just use normal flexible coolant hose? if it needs to be cheap cheap?
Craig
myke pocock
| posted on 27/9/09 at 10:03 PM |
Try ebay.
mark chandler
| posted on 27/9/09 at 11:24 PM |
There is a reason that car manufacturers use rubber hoses, its cheap and last years for water cooling, the only place you really need silicon on
turbo/intercooling pipework, and then only where its going to get really hot or massive boost.
The locost way is to plumb in ali, pop down to B&Q and get a kinked TV aerial pole and cut out the bends and straights or use central heating
copper tube, my choice as I had so old 1" stuff lying around.
You will need to put a bead in the ali, see here link, for copper just solder on
olives.
Regards Mark
A1
| posted on 28/9/09 at 02:50 AM |
Pirtek...theyre not cheap cheap but theyre really good
andkilde
| posted on 28/9/09 at 04:41 AM |
Go down to the local heavy truck center or possibly a full service hydraulic shop and ask for silicone coolant hose. It comes in 3' lengths for
about $8 a foot (~£4).
A truck parts place (or breakers) will get you preformed ali elbows and the nice t-bolt clamps that don't pinch the hose like a worm gear clamp
can as well.
It's not "pretty & shiny" like samco motorsport stuff but it's just as tough.
t
Blackbird Rush
| posted on 28/9/09 at 06:29 AM |
Cheepest place i found was www.siliconehoses.com use ali tube for the straight runs.
Copper pipe T pieces are also good to use.
I used.....
Silicone - 3 x 90's, 3 x 45's a length of straight offcut for joining (got cheep of LB), a straight reducer (38-25).
Ali tube for straight and a Copper T piece
Wasn't cheep cheep over all but the cheepest i could have done it in silicone and keeps it all neat & tidy.
Ash
dunk3
| posted on 28/9/09 at 06:41 AM |
I got mine from (auto performance silicone hoses). sorry cant do the linky thing.
franky
| posted on 28/9/09 at 07:47 AM |
Cheapest so far www.auto-performance.co.uk
1 x Silicone Straight Hose 32mm 1/4" ID 1/2 Metre £10.97 Excl
£12.62 Inc 2 x Alloy Hose Joiner 25mm 1" OD Polished £6.10 Excl
£7.02 Inc 1 x Silicone Straight Hose 25mm 1" ID 1 Metre £13.57 Excl
£15.61 Inc 1 x Ace Hose Clips - 23mm to 35mm 10 Pack £7.07 Excl
£8.13 Inc 6 x Metal Hose Joiner 32mm 1 1/4" £20.10 Excl
£23.12 Inc 1 x Silicone Straight Hose 32mm 1/4" ID 1 Metre £17.40 Excl
£20.01 Inc 2 x Silicone T Piece Hose 32mm 1 1/4" ID £18.06 Excl
£20.77 Inc 4 x Silicone Elbow 90 Degree Hose 32mm 1 1/4" ID £32.08 Excl
£36.89 Inc
Rubber hose is only about 15% cheaper than silicone from the above, still looking around though and will look at alloy tube
wilkingj
| posted on 28/9/09 at 08:18 AM |
I had a long chat with the chap from Viper Performance at Stoneleigh. Some silicone hoses are cheaply made in China.
I got mine from Viper Performance.
http://www.viperperformance.co.uk/
They have an extra layer inside (The black layer)
Cheapest is not always the best.
I also agree that you can use standard hosing which is cheap and then change to silicone hose later.
It took me 3 years to get all my engine bay silicone hosed. It also cost over £100.
Best thing is to start with std hose, and spend the money where its needed.
Of course if you have a bottomless pit of money, go for the silicone straight off.
I certainly have no complaints about Viper performance hoses (No commercial connection, or friend of etc etc with the company either)
I would also use quality clamps on the pipes. Make sure the joining pipe has a raised portion to prevent the hoses / clips coming off when under
pressure.
ie use good parts and do the job properly. That makes for a good all round job, and a more reliable car.
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 28/9/09 at 10:01 AM |
The only thing I would say with auto performance is be a bit careful. I was trying to buy a 28mm hose joiner off them and first they sent me a
non-standard 28mm joiner (which was 27.5mm so leaked) and then when I asked for a 30mm flanged joiner (IE next size up) they sent me a 32mm unflanged
joiner.....
Also- they advertise under quite a few names on Ebay....
I ended up using copper pipe and normal rubber hose.
MakeEverything
| posted on 28/9/09 at 11:49 AM |
Anyone know where to get the beading tool from?? Ive looked everywhere.
Kindest Regards,
Richard.
MakeEverything
| posted on 28/9/09 at 12:35 PM |
Only place i can find is:
Here
Kindest Regards,
Richard.
Blackbird Rush
| posted on 28/9/09 at 08:08 PM |
Top tip.... if you cant get the tubes swaged or if you cant use olives with copper pipe....then...
on the alloy tube, put 2 (or more) pop rivets in to the pipe at even intervals round the diameter of the tube, these will give the hose clips
something to grip against as the pressure builds.
