Author: Subject: Confused With Master Cylinders
MikeFellows
posted on 29/9/09 at 08:15 AM Reply With Quote
Im totally stuck on master cylinders
I currently have a sierra one that used a servo but im being told its too long.
I looked at the compact wilwood ones but firstly i dont know which size and secondly they only seem to have 1 connection (where as the sierra has 3 (2 fronts and a single rear)
on the single connector ones do I just T piece the pipe more?
edit to menition im running wilwood powerlites at the front and standard sierra dics at the rear
[Edited on 29/9/09 by MikeFellows]
t16turbotone
posted on 29/9/09 at 08:20 AM Reply With Quote
with the willwood items you would usually have two items, one from rear circuit, and one for fronts complete with bias bar. i dont think you will be able to 'tee' with one master cylinder as i sure there is a rule about separate circuits for front and rear
Daddylonglegs
posted on 29/9/09 at 08:27 AM Reply With Quote
For fear of hijacking the thread, I'm having a similar dilema. Not sure whether to go for reconditioning the sierra one I already have, or as MikeFellows says, go with something else 'cos the sierra one is not suitable.
Running standard 9" drums on the rear (live axle) and cortina discs on the front.
JB
theconrodkid
posted on 29/9/09 at 08:35 AM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=113482
what i did
who cares who wins
pass the pork pies
MikeFellows
posted on 29/9/09 at 08:37 AM Reply With Quote
doesnt having two master cylinders cause issues with the IVA?
twybrow
posted on 29/9/09 at 08:51 AM Reply With Quote
DDLL - that is my setup (9" drums, with stock M16 cortina stuff up front). I use a 0.75 for the fronts and a 0.625 M/C for the rears, with a balance bar to get it just so. I have found it really hard to balance the two, as the 9" drums are really very effective.
JB
ali f27
posted on 29/9/09 at 08:53 AM Reply With Quote
brakes
Hi you will need duel circ for brakes for test can be done with 2 master cylinders or twin piston i have 2 with balance bar work great .625 on front .7 on rear
ali f27
posted on 29/9/09 at 08:55 AM Reply With Quote
twybrow try swapping them round needs smaller one to the front
twybrow
posted on 29/9/09 at 09:10 AM Reply With Quote
Ooops, I think I meant the other way around. I'm just pleased it works, as changing them once the car is paneled is a right PITA!
Daddylonglegs
posted on 29/9/09 at 09:33 AM Reply With Quote
Just to show my complete ignorance, how does the balance bar fit into the system (i.e. a diagram please )
MikeFellows
posted on 29/9/09 at 09:36 AM Reply With Quote
so i think i now need....
clevis pin attachment to pedal that will connect a push rod to a balance bar
balance bar to 2 master cylinders (0.625 front and 0.75 rear) with resevoirs.
is there anything else?
MikeFellows
posted on 29/9/09 at 09:50 AM Reply With Quote
I found a great webpage with a load of pictures
http://www.robcollingridge.com/kitcar/design/brakes/index.html
It makes it a lot clearer
vindicator
posted on 29/9/09 at 10:54 AM Reply With Quote
Just read the write up from the link, the pics are good and worth noting the brake light switch set up, which I am trying to convert from the fluid push system to a micro switch. The one picture that is missing is how to mount the switch to the brake pedal......dohhh!!!
any one got any pics as I don't want to drill to many holes in the floor to get it right.....
Regards
timr.spaces.live.com---build blog
adithorp
posted on 29/9/09 at 12:17 PM Reply With Quote
If you want to use a single master cylinder I believe one from a fiesta without servo gives good results.
http://jpsc.org.uk/forum/
posted on 29/9/09 at 05:34 PM Reply With Quote
Whats wrong with the Sierra master cylinder? Why isn't it suitable?
Phil
MikeFellows
posted on 29/9/09 at 07:46 PM Reply With Quote
Phil
I keep reading that it requires too much pressure to get the car to stop due to usually having a servo?
posted on 30/9/09 at 06:00 PM Reply With Quote
Loads of people have used the Sierra master cylinder without any problems whatsoever. Whilst there may be more efficient brake master cylinders on the market, the Sierra one is quite capable of stopping a seven without a great deal of effort.
Phil
omega 24 v6
posted on 30/9/09 at 08:45 PM Reply With Quote
Agreed BUT not all people have the same feel for the effort required. I for one would like to "feel" that the car is more under control under braking. My son says he can "feel" how much the car is slowing ,but for me the effort put in does not relate directly to how much I "feel" the car should be slowing.
Also if you have sierra parts all round then obviously the system will be better balanced as it's a proven setup.
I have cortina fronts with M16 calipers and fiesta discs at the rear with golf calipers which may or may not be a bit of a mismatch for the sierra cylinder. So yes they do work Phil but some of us are looking for a "better feel to the pedal"
col
posted on 4/10/09 at 06:55 PM Reply With Quote
Is the mondeo brake master cylinder any good ?
