Author: Subject: R1 electrics powering gauges and switches
corrado vr6
posted on 30/9/09 at 09:21 PM Reply With Quote
Hi again, wondering how to go about getting a live feed to all my savage switches and gauges. I have a 06 R1 i have used the r1 clocks and loom.
1 idea i have is to take a feed from here
run it to a fuse then to the first gauge and spur off to each other gauge and switch.
Is this ok? or is there a easier better way?
Thanks Greg
http://r1indy7.wordpress.com/
barbarianbeast
posted on 1/10/09 at 06:42 AM Reply With Quote
i just took live and ignition feeds off the column wiring, add fuses off course.
one off those wires in your pic already runs back to the ignition any way.
are you using the mk loom at all? i gave up with it and just extended the r1 loom.
