Author: Subject: Zetec with polo Rad in Avon
Ian D
posted on 5/10/09 at 09:14 PM Reply With Quote
Guys,
I have bought my polo rad and have started looking at the job. Has anyone fitted the Polo rad in an Avon with a Zetec? If so do you have any pictures?
Im trying to work out hoses and the alloy tubes and wheres the best place to fit bits.
Ian
edspurrier
posted on 5/10/09 at 09:55 PM Reply With Quote
Yes, I have recently. I'll put some pics in my archive when I get a chance, which may be some time!
Essentially - bottom hose: in to silicon elbow, joined to another elbow to make an S whjich goes over the steering rack. That connects to a T piece, off which comes the expansion pipe hose fsacing down. Another T piece with the thermostat bottom hose connection (from the housing exhaust side) connected. then in to the water pump via an expanding elbow.
the induction side thermostat outlet is blanked off as I have no heater.
Just have an elbow coming out of the large stat outlet, in to long ally pipe, then a fairly long bit of straight silicone pipe into the top.
the 8mm bleed outlet goes through a 1 way valve then connects to a Y piece - the other leg of the Y inlet is from the top of the stat- then the conjoined pipe goes in to the to of the expansion tank.
jamrogers
posted on 8/10/09 at 11:07 PM Reply With Quote
jamstigeravon.blogspot.com
pictures on there
now bent after an accident at the weekend
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
Ian D
posted on 11/10/09 at 02:29 PM Reply With Quote
Thanks, Sorry to hear about your accident. Hope your ok.
Ian
Ian D
posted on 11/10/09 at 02:59 PM Reply With Quote
The Polo Radiator is in. I spent a couple of hours yesterday at the scrapper looking for hoses. Found 2 really useful ones off a Rover 216 early model. The radiator top hose and the 3 way breather pipe.
I managed to use the existing Tiger supplied short tube with the take off points and was able to tee onto the water pump output hose as well. The majority of the plumbing is ahead of the steering rack so getting away from the problem of feeding 32mm hoses around it.
The radiator is almost vertical at a distance of 150mm from the front Chassis tube.
Pictures below.
Rover top hose on the tiger short pipe.
Rover 3 way hose for the breather pipes and the water bottle
Side on view of the hoses
Top hoses
Ian D
Ian D
posted on 11/10/09 at 03:00 PM Reply With Quote
Ian D
Ian D
posted on 11/10/09 at 03:01 PM Reply With Quote
Ian D
posted on 12/10/09 at 08:20 PM Reply With Quote
