40inches
| posted on 24/10/09 at 10:57 AM |
Bore and sleeve a hole without drilling
http://www.youtube.com/watch?v=NhkWINPRK3A&feature=related
speedyxjs
| posted on 24/10/09 at 11:03 AM |
cool!
Iv often wondered how they do that
daviep
| posted on 24/10/09 at 11:04 AM |
These are ace, I've had a sample lying in my toolbox for ages. Much quicker and tidier than rivnuts. Google
FLOWDRILL.
Davie
| posted on 24/10/09 at 12:03 PM |
I'd guess that you'd need a fairly solid and powerful drilling machine to do that - the text says 1.5 - 3.5KW, which is 2 - 4.5 HP (I
think). Also strong enough to allow a fair bit of pressure on the bit too...
Interesting process though...
Dangle_kt
| posted on 24/10/09 at 12:17 PM |
how much is the starter set? would be great for chassis rails instead of rivnuts
| posted on 24/10/09 at 02:03 PM |
that chuck must spin at a fair rate of knots!!!
I wonder if my clarke pillar drill can do that and up to what size? 8 mm would be plenty I guess I'd settle for 6 mm.
40inches
| posted on 24/10/09 at 04:40 PM |
not possible with a DIY bench drill
http://www.centerdrill.de/html_en/faq.html
Jenssteffen
| posted on 26/10/09 at 08:12 AM |
Machines required
Hey all, sorry recieved an inquiry through the website, so thought I would have a look at the locost builders forum.
For doing up to 2mm with an M8 you will need 1.5 HP and about 2000 RPM, you can just about get away with 1.25HP but the tool life time will be a
lower. If your bench drill can manage that it shouldnt be a problem to do it. The clamping must be with a collet, as with a normal 3 pronged chuck the
drill will slip because of the high axial force and torque.
Also if you want to have a look at http://www.flowdrill-gmbh.de/english/flow2go_en.htm it is sadly not hands free but can be placed on a work bench
nicely.
Hope you guys keep up the good work on the forum and if you have any questions just ask.
