Author: Subject: Zetec cams timing belt tension(silvertop)
bob
posted on 25/10/09 at 04:25 PM Reply With Quote
OK so if i havnt got the spring to pre tension the cam belt tensioner is their an idiots guide ?
austin man
posted on 25/10/09 at 04:33 PM Reply With Quote
tension it then turn the egine over by hand through 360 degrees, the longest section of belt should twist through 90 degrees any less its too tight any more too slack. the odd degree doesnt really matter.
bob
posted on 25/10/09 at 04:40 PM Reply With Quote
Cheers thanks for that, longest run on belt from exhaust cam pulley to crank does twist 90 degs with a little effort.
I'll put the rest of the bits back on in the week then wait for a brave moment and turn the key
austin man
posted on 25/10/09 at 04:41 PM Reply With Quote
that method hs never let me down, all the best, you did take the engne through 360 before tryig didnt u
bob
posted on 25/10/09 at 04:54 PM Reply With Quote
Yep i turned it over 360 and made sure the timing marks and cams still aligned.
posted on 25/10/09 at 05:17 PM Reply With Quote
New tension spring and peg should only be a few pence from Ford , hole is already tapped for the peg
bob
posted on 25/10/09 at 05:29 PM Reply With Quote
Thanks mel, i may well find the spring if have a bit a clear up
adithorp
posted on 25/10/09 at 05:57 PM Reply With Quote
...and it's 2 full turns to get the timing marks to line up again and a 4stroke.
http://jpsc.org.uk/forum/
marcyboy
posted on 25/10/09 at 09:27 PM Reply With Quote
Bob...just use the FORCE!!
