Author: Subject: Zetec 2.0 pre blacktop, what to get it on carbs?
AdrianH
posted on 25/10/09 at 07:06 PM Reply With Quote
This is a what if question, as presently running CVH.
The pre-blacktop zetec in 2 litre being a fuel injected system What is the simplest way to fit a carb system. Is there any manifold and standard carb that would fit directly to it and allow use of a megajolt system?
Adrian
Why do I have to make the tools to finish the job? More time then money.
UncleFista
posted on 25/10/09 at 07:55 PM Reply With Quote
The Zetec never came with carbs, so there's nothing OEM available.
The closest I've seen is a cut and shut manifold on eBay so you can bolt a twin-choke weber to one, usually used by banger racers and not something I'd use.
I reckon you're down to either twin carbs (webers etc.) or (my preference) motorbike carbs.
Webers will be expensive, especially ones suited for Zetecs (if you fit any old carbs you'll have problems tuning them).
As for bike carbs, you can order a set of carbs and manifold complete, ready to run from Bogg brothers in North Yorks, or make a manifold yourself and buy some carbs off eBay, or any choice between the two.
The ST170 inlet manifold is plastic and can be cut about to fit respaced carbs too.
Our setup for our silver-top Zetec cost no more than £30-40 including the hose
medium
medium
[Edited on 25/10/09 by UncleFista]
Tony Bond / UncleFista
woolly
posted on 25/10/09 at 08:08 PM Reply With Quote
try mark at SRD 01566 778779
i think he does one for a 32/36
woolly
will121
posted on 25/10/09 at 08:11 PM Reply With Quote
cheapest options individual motorbike throttle bodies standard ford ECU or motorbike carbs and megajolt both on home made manifold
or for a bit more a ready made bogg set up
AdrianH
posted on 25/10/09 at 08:19 PM Reply With Quote
Cheers Tony, not sure if of use to anyone but a silvertop Zetec on the bay at moment, Linky
I was wondering what to do as an in case situation, as in what if mine breaks, would it be easy to?
I may just look for another 1.8 CVH as insurance.
Thanks for the post. I have herd of Blogg brothers but never had need to use their services yet. I will do a search and look at their site.
Many thanks
Adrian
It is taking my pc ages to update and get back to page about to give up and realised more replies, thanks guys.
[Edited on 25-10-09 by AdrianH]
big_wasa
posted on 25/10/09 at 10:52 PM Reply With Quote
Weber dcoe 45's
and as it so happens they are for sale.
zetec7
posted on 28/10/09 at 06:02 AM Reply With Quote
As it happens, there are manifolds to fit Weber 45DCOE's that are very nice indeed. I bought mine on Ebay, as I did with the Webers. In concert with a very simple ignition system (not requiring an ECU of any kind) purchased from www.quad4rods.com it makes an inexpensive & basically bulletproof conversion. Looks the part, too, in my opinion.
http://www.freewebs.com/zetec7/
