Poll: Will My Engine Run?? [View Results]
Yes
No
Author: Subject: Will My Engine Run??
ashg
posted on 30/10/09 at 12:06 PM Reply With Quote
Little poll. megajolt setup with zx6r bike carbs on a 1600 pinto.
I have tested the mjolt on the bench and know it to be working. i have made the bike carb manifold and fitted the bike carbs to the engine. i have changed nothing on the bike carbs they are setup exactly the same as the day they were removed from the bike.
what do you think will it run or will it not start at all?
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Mr Whippy
posted on 30/10/09 at 12:10 PM Reply With Quote
Should do, so long as you remember the fuel tank
blakep82
posted on 30/10/09 at 12:13 PM Reply With Quote
mine ran exactly the same way. although i didn't connect the MJ, just used edis
________________________
blakep82
posted on 30/10/09 at 12:16 PM Reply With Quote
oh, and also don't wire all your positives and negatives together, like someone did on mine...
Mr Whippy
posted on 30/10/09 at 12:20 PM Reply With Quote
yeah that sounds safe
blakep82
posted on 30/10/09 at 12:37 PM Reply With Quote
oi, i didn't do it! its because the wires on the edis are all stupid colours. black for positive, brown for negative (both negative/earth colours to me) my dad did it though, even though i gave him all the diagrams
cd.thomson
posted on 30/10/09 at 12:38 PM Reply With Quote
ash, the megajolt first-start procedure suggests that you should try it with just EDIS first (a la blakey) before megajolt is connected to anything.
It helps to narrow down problems if things don't go to plan.
my 2p is that after a bit of nervous cranking itll burble happily into life
Craig
omega0684
posted on 30/10/09 at 01:35 PM Reply With Quote
round of applause for craig for the exquisit use of the word burble, although used a little meterphorically!
Mr Whippy
posted on 30/10/09 at 01:48 PM Reply With Quote
oh that's nice blaming your poor dad
ashg
posted on 30/10/09 at 02:18 PM Reply With Quote
it would be interesting to know what size jets etc people are running on 1600 pintos. thats if there is anyone with a 1600 pinto on bike carbs lol.
andrewcutchey
posted on 30/10/09 at 02:22 PM Reply With Quote
I'm glad the MJ is working!!!
cd.thomson
posted on 30/10/09 at 02:37 PM Reply With Quote
Hey Ash,
I recently spoke to Bogg about jetting.
they drill out zx9rs to 1.8mm for 2l engines but they said that this is just a very general rule of thumb. Often when on the RR they run better less rich (at 1.7mm)
Again this is the zx9rs but the standard jet size is somewhere around 1.5mm - 1.6mm (testing with my own drill bit!) so I dont know whether to suggest running the zx6rs as standard on a 1.6l at first?
I very much doubt the standard jets will run it lean enough to damage anything so best to suck it and see. If the engine wont rev over 4000rpm then you know you need to have a play with them.
[Edited on 30/10/09 by cd.thomson]
Craig
ashg
posted on 30/10/09 at 02:39 PM Reply With Quote
yep edis working all hunkey dorey
here is a little video of it running on the bench
Click
[Edited on 30/10/09 by ashg]
mookaloid
posted on 30/10/09 at 04:33 PM Reply With Quote
Try RichardK
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 30/10/09 at 04:35 PM Reply With Quote
a couple of pessimists i see
DRC INDY 7
posted on 30/10/09 at 05:19 PM Reply With Quote
i ran mine at 1.50mm
The jet sizes before drilling were 1.15mm i ran it at that till i got round to drilling them out to 1.50mm
The fuel mixture setting will have to be adjusted bike carbs are set rich
my engine was 1600 pinto with plus 1mm pistons high pressure oil pump standard 2 litre camshaft with zx6r bike carbs timing set at 14 degree's btdcpower all the way through the range co% set at 2.5 this helps keep the pistons cool and full power
[Edited on 10/31/2009 by DRC INDY 7]
Puddle Dodgers Club
blakep82
posted on 30/10/09 at 05:28 PM Reply With Quote
aye thats right! i gave him the wiring to do while i bolted up the carbs, manifold and fuel lol
blakep82
posted on 30/10/09 at 05:31 PM Reply With Quote
Click
lenovo t60?
lotusmadandy
posted on 30/10/09 at 06:15 PM Reply With Quote
I ran a 1600 pinto on zzr1100 carbs,
the jets were drilled out to 1.5mm.
I had no problems at all.
austin man
posted on 30/10/09 at 07:07 PM Reply With Quote
DRC INDY 7 is using bike carbs on a 1.6 pinto, it goes well enough I think the jest are 1.5
Drop him a u2u
ashg
posted on 31/10/09 at 12:01 AM Reply With Quote
blake its a lenovo t400
its actually my work one. its a pile of poo for a brand new high spec laptop. my old dell with half the spec run better
posted on 31/10/09 at 09:27 AM Reply With Quote
I think that's a little inappropriate to be honest, especially as we have several builders of the fairer sex on here.
MakeEverything
posted on 3/11/09 at 01:02 PM Reply With Quote
I think thats a little inappropriate as well tbh, seeing as its;
A) True
B) Referring to a minority
C) True
D) True
E) We all have Tits of some desciption
The guy in James Bond had three - As did the bird in Total Recall.
[Edited on 3/11/09 by MakeEverything]
Kindest Regards,
Richard.
