Author: Subject: fireblade carbs (edited)
55ant
posted on 23/11/09 at 10:24 AM Reply With Quote
i have a set of fireblde carbs (with tps) with three wires on the left of the carbs, i have no idea what these are for, nor what to wire the to, does anyone know?
ok so the yellow circle is the three wires that i dont know what they are for
blue - is the fuel line
green - is a vent pipe.
red - vacuum pipe from engine block (in which you can put a catch can)
yellow - havnt looked at this one yet but does anyone know?
the pic is not my engine, but they are my carbs.
cheers, ant
[Edited on 23/11/09 by 55ant]
away from cars, now cycling and building TT bikes
RAYLEE29
posted on 23/11/09 at 10:49 AM Reply With Quote
Hi, the big black hose on top is the vent tube as for the wires cant see which you mean where do they go?
Ray
andrewcutchey
posted on 23/11/09 at 11:05 AM Reply With Quote
They are for the TPS which you do not need with your dizzy. Tie them off though as you may want them later if you change to megajolt.
Andrew
GreigM
posted on 23/11/09 at 11:16 AM Reply With Quote
I think the yellow line points to the accelerator cable...
Andy B
posted on 23/11/09 at 02:27 PM Reply With Quote
Red is float bowl vent pipes - leave open to atmosphere unless forcing the airbox in which case plumb it into airbox
3 wires on the end have been correctly identified as TPS which feed signal to ecu on 96 to 99 carbed blades
regards
55ant
posted on 23/11/09 at 04:10 PM Reply With Quote
okay, so where does the oil/vacuum hose from the block go? theres no fitment on the manifold, as there was on the downdraught manifold.
jacko
posted on 23/11/09 at 04:54 PM Reply With Quote
If you mean the breather pipe remove the one way valve by cutting the end off the valve will come out than the pipe wants to go to a oil catch tank
