Author: Subject: Wtd: T25 Turbocharger
MakeEverything
posted on 5/12/09 at 02:20 PM Reply With Quote
As title.
I think i may have blown my second hand (Suspect anyway) turbo bearings. Does anyone have (or can get hold of) a T25 turbo? Preferrably from a renault 21 but anything of a similar size will do. Failing this, its a new £300 (upgrade) job from the states.
Kindest Regards,
Richard.
l0rd
posted on 5/12/09 at 02:24 PM Reply With Quote
I thought that the T25 was a popular upgrade for R5
liam.mccaffrey
posted on 5/12/09 at 02:26 PM Reply With Quote
i have a turbo from a Volvo B5234T engine. I was told it was a good running engine when I bought it
I have switched it out for a supercharger
MakeEverything
posted on 5/12/09 at 02:30 PM Reply With Quote
I have a 2.2 renault engine in the kit car, which ive fitted a turbo to. IT works VERY well, but the bearings are shot.
It probably was a popular upgrade for the R5, but ive never had one so not sure.
Kindest Regards,
Richard.
posted on 5/12/09 at 03:10 PM Reply With Quote
Rover T16 has a T25 on it, mine does anyway, hopefully going to my long term plan for a cheap turbo zetec
TPG
posted on 5/12/09 at 03:17 PM Reply With Quote
This may help Link .I have had these kits in the past and he is very quick a very reasonably priced.
..Which was nice..
Avoneer
posted on 5/12/09 at 04:34 PM Reply With Quote
200SX as well.
Can you just not get a bearing kit off ebay for about £50 and see if it'll do the job?
Pat...
MakeEverything
posted on 5/12/09 at 05:28 PM Reply With Quote
I could, but im looking at cheap alternatives as its a prototype at the moment. Stripping it completely will be a last resort, where ill clean everything thoroughly and build it to last.
Kindest Regards,
Richard.
boggle
posted on 5/12/09 at 07:02 PM Reply With Quote
i have a tdo4l off of a subaru impreza.....
MakeEverything
posted on 5/12/09 at 08:32 PM Reply With Quote
Im listening......
Kindest Regards,
Richard.
boggle
posted on 5/12/09 at 09:10 PM Reply With Quote
it has covered 50,000 miles and is mint...should be good for 280 bhp, it is very fast spooling too, but it has a different flange to a garret unit, i could possible cut you a pair of flanges to suit thou???
im open to offers, and could post a pic tommorow?
MakeEverything
posted on 5/12/09 at 09:30 PM Reply With Quote
Sounds good. With fear of offending (and a limited budget) id be interesting to hear what you thought was a reasonable offer once ive seen the pics. - Drop me a U2U or Email with the pics and we'll sort it out away from the forum.
Cheers.
Kindest Regards,
Richard.
Volvorsport
posted on 6/12/09 at 02:30 PM Reply With Quote
td04 is the same as the garret t3 , so IIRC it will fit the t25 , but not the 3 bolt flange of the t28 .
any number of the volvos have td04 .
940 - 13c
850 - 15g
s70 - 16t-19t
c70 - 18t
etc etc .
ive got t3 flanges off the shelf for a couple of quid , but i think you wont need it .
www.dbsmotorsport.co.uk
getting dirty under a bus
boggle
posted on 6/12/09 at 02:37 PM Reply With Quote
some pics of the unit.....i had a t3 off of an rs turbo that i once used to turbo charge a zeetec...i remember the inlet flange was a 4 stud square flange and the outlet was bolted to a cast elbow, so they may be the same??
MakeEverything
posted on 6/12/09 at 04:15 PM Reply With Quote
Thanks fellas, a big help.
Is it possible to unbolt and rotate each of the housings to the correct orientation? The one above for example, would have the oil inlet and outlets horizontal if i mounted it to the existing manifold.
The other option of course, is to make an elbow for the manifold, but i want to keep things simple.
Kindest Regards,
Richard.
MakeEverything
posted on 6/12/09 at 08:21 PM Reply With Quote
Ive found a replacement, courtesy of Boggle, and have my eye on the new replacement next year once the tests are complete....
http://cgi.ebay.co.uk/Super-T70-T3-Turbo-Charger-4-70-AR-Stage-IV-35psi_W0QQitemZ130314135082QQihZ003QQcategoryZ72205QQcmdZViewItemQQ_trksidZp3286.m7Q Q_trkparmsZalgo%3DLVI%26itu%3DUCI%26otn%3D2%26ps%3D6
This would be my opportunity for Megasquirt and an engine rebuild.
Kindest Regards,
Richard.
Avoneer
posted on 8/12/09 at 05:29 PM Reply With Quote
I'd be very warey of a "china charger".
Better with a 2nd hand unit off ebay.
200sx go for less than £50 on ebay sometimes.
And yes, either end can be rotated to any angle - just the middle you have to keep vertical with the oil drain underneath.
Pat...
[Edited on 8/12/09 by Avoneer]
MakeEverything
posted on 8/12/09 at 09:56 PM Reply With Quote
Cool, Thanks.
Kindest Regards,
Richard.
