Author: Subject: best place to go for diff rebuilt
antonio
posted on 21/12/09 at 07:16 PM Reply With Quote
hi
i'm looking for someone capable of putting my new LSD in my diff.that may sound crazy but no one here in france to help.i tried to do it by myself, but i can't unscrew the two bearings (if you understand what i try to say!)
if someone can advise me a good place to go (in kent would be good!) or if someone here is able to do it for good money, i would be very happy.
best regards, merry Xmas
antonio
prawnabie
posted on 21/12/09 at 07:18 PM Reply With Quote
procomp are good
Coopz
posted on 21/12/09 at 07:25 PM Reply With Quote
Phil at Road and Race did my diff fantastic guy and great service turned it around in a day! Looked brand new I believe he rebuild most of Caterham's too!
Road & Race Transmissions
The Bullock Shed
Filston Farm
Shoreham, Kent ( In kent too)
TN14 5JU
tel: 01959 525105
mobile: 07836 333882
Project7
posted on 21/12/09 at 09:35 PM Reply With Quote
Yup, I can reccommend Phil at Road and Race too.
Steve Hignett
posted on 21/12/09 at 09:39 PM Reply With Quote
As above, road & race
Willie
posted on 21/12/09 at 10:24 PM Reply With Quote
Antonio, (Class name by the way)
I assume you're talking about a Sierra diff, and by unscrew the bearings you mean the big castellated nuts on the sides that contain the bearings?
These:
Get the diff into a vice and if you can get a bit of heavy flat bar that's just thin enough to fit between the teeth, and long enough for stacks of leverage, you should be able to get them shifted. Here's what I use:
If that's still difficult, soak around the edge of the nut with WD40 and let it sit overnight.
I fitted my own LSD and intend to do some rebuilding soon, as I'm tranferring my LSD into a different ratio diff. If you take your time, its actually quite easy. I advise measuring the backlash before you dismantle the side nuts, so you know how far in to mesh the crownwheel on re-assembly.
Hope this helps,
Willie
mark chandler
posted on 21/12/09 at 11:24 PM Reply With Quote
As above, but for a little extra help use a blow torch to heat the surround, do not get really hot as there is a rubber seal but it helps to get started. Once they move they come out easily enough.
Regards Mark
antonio
posted on 22/12/09 at 07:37 AM Reply With Quote
cheers for your answers guys!
i didn't try to loosen the big castellated nuts because i suspected them to brake if i don't use the right tool.
i'll try this week end
many thanks
antonio
Mopple
posted on 22/12/09 at 10:36 AM Reply With Quote
For assurance you could weld extra pieces of flat far perpendicularly to distribute the load more evenly.
Willie
posted on 22/12/09 at 05:33 PM Reply With Quote
They shouldn't be too tight as you set them like you set a wheel bearing, wind in until there is no more play in the crownwheel. I can't mind if you then wind on a few teeth preload or not.
Any I've played with, so far, have been easy enough to shift.
Willie
