Author: Subject: Savage switch wiring help
FFTS
posted on 21/12/09 at 11:24 PM Reply With Quote
Got some savage switches but some without wiring instructions. Also saw this video on youtube and love how this guy has wired his to have 2 levels of illumination > Illuminated and ON (brighter) so it shows clearly which switches are on. He mentioned a diode and resistor wired in to each switch.
Anyone know what to ask for at maplins and where to wire them in.
Video Linky
Chris.
sucksqueezebangblow
posted on 22/12/09 at 09:25 AM Reply With Quote
No need for a diode. The switches are double throw (i.e two switches in one) one throw one side and one throw the other. All you need to do is put a resistor on one of the throws so that when the switch is off current flows through the resistor from the side light circuit to the LED but when the switch is on current flows directly from switched positive to the LED. Ill post a diagram shortly.
Savage Dim Wiring
Savage Dim Wiring
As you can see one pole of the switch connects to positive if you always want them bright lit when on (day or night) and the other pole connect through a resistor to side light switched positive so that they come on dim when the side lights are on.
Ahh, I just spotted my mistake, the on and off labels are reversed on the diagram. Should be off above and on below.
[Edited on 22/12/09 by sucksqueezebangblow]
corrado vr6
posted on 22/12/09 at 01:29 PM Reply With Quote
Hi mate, here is a link for what i think your asking for probably the same guy off of the youtube video, although the suggestion above sounds easier HTH Greg
edited to say it is the same guy the same video is at the bottom of page
[Edited on 22/12/09 by corrado vr6]
http://r1indy7.wordpress.com/
FFTS
posted on 22/12/09 at 11:48 PM Reply With Quote
Thanks for that.. very useful
Chris.
