711M Crossflow engine (+full running gear package)
Ill start a new thread as the last one was slapdash.
711M 1600cc Xflow engine, rebuilt 5500miles ago with;
New pistons
New Rings
New Bearings
New oil pump
New Kent cam
New followers, valves, valve springs.
New rocker assembaly
Balanced and lightened.
New crank assembaly
New flywheel
New clutch
All work on the above was done at Brights auto centre in Bristol and comes with a reciept to prove work. The work was done by a friend and been
brillaint since.
Also added is;
Burton rocker cover
4 branch tubular manifold
stainless steel exhuast
NEW thermostat
NEW alternator
Reconditioned starter motor.
NEW spark plugs
HT leads and dizzy
Also included in the sale is;
carbatertor setup for the modifications (£££!)
4 speed gearbox
shortened prop
Diff
engine mounts
And anything else attached to it thats needed to install in new car (im upgrading to a different engine/running gear so the lot can go to the new
owner to make a nice drop in "package"
The whole setup has come me over £3000
I think £1200 is a fair price for the whole lot. It can all be seen and tested before removal.
here are some picture, sorry they are very dusty as the car has been in my garage where I have been doing DIY.
