Author: Subject: luminition wiring
boggle
posted on 28/12/09 at 01:24 PM Reply With Quote
luminition wiring
hi all
wiring is not my strong point and i have been given a dizzy that has been converted to use a luminition kit...
my problem is the plate inside where the points used to fit is fixed, so im assuming i dont need the vac advance as it is not fitted? also i have two wires on the module a red and brown. im assuming they go to the coil? and the brown is of a heavier gauge....maybe to the posotive side of the coil?
cheers
Boggle
u2u me for details
twinturbo
posted on 28/12/09 at 01:39 PM Reply With Quote
you should still have vac advance if it was originaly fitted, unless the ignition module has a vacum port ( lumenition does not )
mine had 3 wires
Lumenition will be able to tell you though.
TT
boggle
posted on 28/12/09 at 11:04 PM Reply With Quote
thanks...had a look on there website and all my questions have been answeard...
u2u me for details
