Author: Subject: Alternator identification help / wiring
r1_pete
posted on 28/12/09 at 04:39 PM Reply With Quote
Can anyone identify this alternator?
Or tell me what the two spade connectors are for, the main battery screw connection is pretty obvious, but what do the other two do? one must be the warning light, but which one? and what does the other do?
Any help greatfully received.
mini alternator
mini alternator
alternator connections
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
Building: a sense of satisfaction now things seem to work ok
posted on 28/12/09 at 05:22 PM Reply With Quote
Looks like mine which if my memory serves me correctly is a kubota tracktor one.
Might have the wiring diagram somewhere...
Chris
Sorry mine has 3 spades........ There is a thread on here somewhere from Flakmonkey I think which has some details on the Kubota alternators.....
[Edited on 28/12/09 by chris-p-duck]
t16turbotone
alot of alternators have a 'tacho' connection so it could be for a tacho
r1_pete
posted on 28/12/09 at 06:18 PM Reply With Quote
Thank You, one of the links in Flak's post has a wiring diagram showing an identical alternator to mine.
2nd spade is for a 12v switched reference feed.
posted on 29/12/09 at 03:54 PM Reply With Quote
correct.
it is identical to my one, albeit the main post terminal is slightly different.
one wire goes to charge lamp, the other is switched live (required else the alternator won't charge).
if you need to know which is which, then lemme know and I'll go out into the cold to look. Rescued attachment DSC04787.JPG
FrankP
posted on 29/12/09 at 04:23 PM Reply With Quote
Have a look here
http://westfield-world.com/daihatsu_alternator.html
Frank
