big-vee-twin
posted on 2/1/10 at 03:07 PM |
Cutting Holes in GRP side Panels
I am planning soon to start cutting my side panels to allow the front wishbones etc. to come through.
Before I mess them up any tips that may help me avoid ruining them!
http://www.triangleltd.com
big_wasa
posted on 2/1/10 at 03:41 PM |
measure twice and cut once ![](/images//smilies/tongue.gif)
AndyW
posted on 2/1/10 at 03:42 PM |
measure three times, cut once, and use masking tape so you can mark where holes etc are going to be before cutting...
Project7
posted on 2/1/10 at 03:52 PM |
If you plan to use tank cutters/holesaws run the drill in reverse, it takes a bit longer but doesnt snatch and chip the gel coat.
[Edited on 2/1/10 by Project7]
Richard Quinn
posted on 2/1/10 at 03:54 PM |
quote: Originally posted by Project7
If you plan to use tank cutters run the drill in reverse, it takes a bit longer but doesnt snatch and chip the gel coat.
Or get some decent
hole saws and run the drill quite slowly until through the gel
Project7
posted on 2/1/10 at 03:57 PM |
Or get some decent
Sorry richard I editted the post just after you quoted me. I meant holesaws.
bodger
posted on 2/1/10 at 04:55 PM |
A Black & Decker power file is good for GRP - sometimes a bit too good, be careful with it.
austin man
posted on 2/1/10 at 05:44 PM |
a dremmel is also a good tool for the more inticrate shapes
rf900rush
posted on 2/1/10 at 06:06 PM |
I also found ceramic tile cutting jigsaw blades work well for large holes and straightish cuts.
And don't forget the masking tape to protect from scatches.
![](http://images.toolstop.co.uk/product/resized/8e6ea74f515f612c15094529c8bf43ca.jpg)
norfolkluego
posted on 2/1/10 at 06:23 PM |
Wear a mask, serious amounts of dust (there again I did use an angle grinder when cutting the hole for my carbs, mans tool, it's pretty quick
too!)
Yorkie
posted on 2/1/10 at 10:24 PM |
As above, measure twice and cut once.
Take care when trial fitting the GTS side panels as they are a tight fit over the chassis rails.
