New Topic New Reply
Author: Subject: clicking noise on tintop
novacaine
posted on 3/1/10 at 04:39 PM Reply With Quote
hi all,
ive got an annoying clicking noise on my car,
it is speed dependant and is coming from the front left,
the annoying thing is i've replaced both of the outer CV joints in the process of trying to get rid of the noise so its not them
any ideas ?
cheers
Matt
***Edit to add its a fiat punto X reg JTD***
[Edited on 3/1/10 by novacaine]
r1_pete
posted on 3/1/10 at 04:40 PM Reply With Quote
Stone in the tyre clicking on the road surface??
novacaine
posted on 3/1/10 at 04:50 PM Reply With Quote
no stones in the tyres,
also the clicking is intermittent
thanks for the input anyway
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
gazza285
Radio not loud enough?
Ben_Copeland
posted on 3/1/10 at 04:55 PM Reply With Quote
My brother in law had a clicking on his corsa.
Turned out to be the subframe was loose but was only noticable at very slow speeds under load.....
Ben
Locost Map on Google Maps
Enter Your Details Here
Mr Whippy
posted on 3/1/10 at 05:01 PM Reply With Quote
if its fwd then just jack a wheel up at a time and let it run in gear to have a look under the car.
Mind to really do a good job of supporting the car while you do this, no jack only cutting corners.
DRC INDY 7
posted on 3/1/10 at 05:27 PM Reply With Quote
i had a wheel bearing go like that on one of my cars
Puddle Dodgers Club
MakeEverything
posted on 3/1/10 at 05:32 PM Reply With Quote
Sounds like a bush or heel bearing?
Also, check youre wheel nuts.....
Kindest Regards,
Richard.
austin man
posted on 3/1/10 at 05:57 PM Reply With Quote
If you've done the CV joints then theres a good chance that its the wheel bearing. I take it the tie wraps/ metal clips you used on the CV Joint are not catching any where.
novacaine
posted on 3/1/10 at 07:26 PM Reply With Quote
thanks for the replies,
any way I can check to see if it is the wheel bearing before i jump in?
also, how much does it cost to have a new bearing pressed into a hub?
New Topic New Reply
