Dangle_kt
| posted on 17/1/10 at 07:52 PM |
prop adaptor - You're twisting my mellon man!
I posted up the other week about my prop coming loose. As I was driving I heard a whirring noise, stopped and found my prop adaptor had a few mm of
play.
I assumed that this meant it was loose, and about to fall off so waited 4 hrs for the RAC to take me home.
I thought it was the inner bolt that secures the prop adaptor to the drive shaft from the engine that had come loose as the 4 bolts that secure the
prop to the prop adaptor were all in place and working fine.
I have been on my jollies for a few weeks, so started on it the other night, and have finnally got the prop off the prop adaptor tonight (pig of a
job! )
I have now found the centre bolt is tight - very tight and only the prop adaptor itself has the play in it, it moves about .5mm approx in all
directions, and if the bolt was loose it would make perfect sense, but it is not loose and has no play whatsoever.
So I'm confused, as I didn't fit the prop adaptor or prop myself, can anyone enlighten me how the main bolt in the centre of the prop
adaptor can be tight and not budge even with significant force applied, but the prop adaptor that I assumed it secured has a very small amount of
play...
The prop adaptor hasn't actually moved at all, and only has this small amount of play - is it ok?
I have a track day next wed and I have missed the last two trackdays I have booked due to technical problems (bikes not cars!)- I really REALLY dont
want to miss another one!
Any advice welcome, and specifically how the prop adaptor is secured to the drive shaft.
Thanks folks!
prawnabie
| posted on 17/1/10 at 07:55 PM |
My first thoughts were the nut bottoming out but if the play is in all directions then my money would be on the output shaft bearing.
Dangle_kt
| posted on 17/1/10 at 08:07 PM |
Thanks I hadn;t thought of that.
I just popped out to go and check and I dont think it can be that, as the output shaft doesn't move when the prop does. I can hold the centre
bolt with my fingers and it stays still but the prop will "wobble" slightly.
prawnabie
| posted on 17/1/10 at 08:09 PM |
I do seem to remember a post from someone saying be careful where you buy the adapters from as some of them are a loose fit.
Blackbird Rush
| posted on 17/1/10 at 08:13 PM |
1.does the bolt move with the prop adaptor? or 2.does the bolt stay still with the prop adaptor wobbling in relation?
1. Prob the gearbox bearings
2. bolt has bottomed out without gripping the prop adaptor, prob needs a washer of sorts.
ReMan
| posted on 17/1/10 at 08:20 PM |
This may hjelp, to sve re-typing...
http://www.locostbuilders.co.uk/viewthread.php?tid=110150
welderman
| posted on 17/1/10 at 08:30 PM |
The only prob with that is, that there are two conflicting pieces of information on that thread:- Yours and Andy Bates (I think) are contradicting
each other. I could be wrong though.
In response to OP.
Some people say that it is actually preferred to have some play in the prop adaptor, others want it tight...
Thank's, Joe
I don't stalk people
Dangle_kt
| posted on 17/1/10 at 08:46 PM |
In response to OP.
Thanks Joe.
Yes I did get a little muddled by that thread when trying to visualise what everyone was saying.
The key question, is can it safetly wait till after the trackday? If I reassemble now and leave it, am I likley to meet mr prop half way up Deer
Leap?
Happy to leave it till afterwards and fix it with a spacer or mill the the back of the adaptor or whatever is best - I just want to know that the
small amount of float on the adaptor isn't going to cause anything to fail.
LBMEFM
| posted on 17/1/10 at 09:28 PM |
I had the same problem on mine, I had a spacer washer made up to ensure the bolt did not bottom out. Barry
ReMan
| posted on 17/1/10 at 09:48 PM |
In response to OP.
Yes I agree, both mine and others do contradict.
Personally I'd prefer it to be tight in a propshaft application, though I would be happy in a bike-sprocket and chain to be a little play as the
loads are uniform unlikely to try and pull a sprocket off the end of the shaft
smart51
| posted on 18/1/10 at 07:56 AM |
I had this
The nut that screws onto the splined shaft is recessed on one side. the recess has to go facing the prop adapter. I had mine on the other way making
the adapter loose despite the nut being tight. When the nut was put on the right way, it clamped the adapter up tight without bottoming out on the
end of the thread.
Neville Jones
| posted on 18/1/10 at 10:43 AM |
Some of the prop adaptors floating about(pun ) are made of 'free machining' steel. ie very soft.
Take the end bolt out, and see if the adaptor is flopping on the shaft. If it is, bin it and get a hardened item.
Nev.
Dangle_kt
| posted on 18/1/10 at 11:37 AM |
I got it from ab performance so I think it will be a good quality item.
Can anyone confirm if having some float will be safe for the trackday, and I can sort it afterwards? Cheers
bigfoot4616
| posted on 18/1/10 at 02:06 PM |
i would give andy a ring then and see what he says
Dangle_kt
| posted on 20/1/10 at 06:43 PM |
I called Andy and wanted to post up the bones of his reply, for future reference if anyone else has this problem.
When I explained the centre bolt (securing the prop adaptor to the drive shaft of the engine) was tight, but that the prop had some play in it, he
imediatly said this comes up a lot.
This is as it is designed, as it isolates some of the force from the prop undoing the prop adaptor, and that if the adptor is tightly secured using
some form of spacer, all that happens is the forces from changing gear (lash I think was the term he used) over time makes the centre bolt work
undone.
He added that r1 prop adaptors often are an exact fit and so the first thing he does is skim 1mm off them so that it has this same play.
I explained that this seems to have started recently though - and he replied that it is usual after a few miles (ive done about 150ish in total) that
the grease is flung from the UJ's on the prop, leading to them loosening up, and the slight play in the prop adaptor causes the prop to become a
little noiseier than it was when packed with grease. he said I would be best using a grease gun sort out the nipples, and also check the rear of prop
is secure as the prop can transmit sound so it sounds like the front when it is the back.
Just so everyone knows Andy's take on the situation, I thought I'd explain, as to be honest I didn't grasp that from the last thread
on it.
afj
| posted on 20/1/10 at 07:20 PM |
Mines loose at the engine end and has been that way since SVA 3000 miles ago seems ok
eerrrrrrrrrrrrrrrr
