<<  1    2  >>
Author: Subject: Most Devious ways to grenade an engine.
liam.mccaffrey
posted on 19/1/10 at 05:57 PM Reply With Quote
We discuss this in work all the time.
My favourite is a ball bearing down each cylinder. Though not particularly quick to do.
I think in the states the authorities run the engines f confiscated car with some sort of resin until they stop
[Edited on 19/1/10 by liam.mccaffrey]
Build Blog
Build Photo Album
Tatey
posted on 19/1/10 at 06:00 PM Reply With Quote
What about replacing the oil with some kind of liquid which sets when it reaches the right temperature?
tomgregory2000
A grenade in the engine bay and a piece of string attached to the pin and the other end attached to a solid object.
Drive off and BOOM
liam.mccaffrey
posted on 19/1/10 at 06:01 PM Reply With Quote
Yes! Literal as well
Drive off and BOOM
@Tatey I was writing my edit when i saw your post
Build Blog
Build Photo Album
speedyxjs
posted on 19/1/10 at 06:04 PM Reply With Quote
Start the engine then pour water in the fuel tank
posted on 19/1/10 at 06:05 PM Reply With Quote
By grenade do you mean knacker?
Aliminium oxide grinding powder down the dip tube?
Otherwise a piano TG vs. Marina stylee does the job.
bi22le
posted on 19/1/10 at 06:08 PM Reply With Quote
pull of a water hose. Nobody would notice that in a normal car. Untill the warning light comes on that is!
Please read my ring story:
posted on 19/1/10 at 06:09 PM Reply With Quote
what's that going to do? Unless you leave it for a long time and your engine goes all rusty? Water injection is used on boosted engines (okay, it's not stuck in the blooming tank but the principles the same)...
posted on 19/1/10 at 06:11 PM Reply With Quote
Yup- my mate found someone had slashed the lower radiator hose on his work van (presumably to follow him and do him over a little up the road- he's a jeweller). Nasty- the light won't come on because that's normally bathed in the coolant. No coolant- no heat transmission, first thing you know is the engine seizing....
Rod Ends
posted on 19/1/10 at 06:15 PM Reply With Quote
Cash for Clunkers - destroying engines the Govt. mandated way!
Liam
posted on 19/1/10 at 06:32 PM Reply With Quote
What are you looking for exactly? Rapid violent destruction, slow but stealthy, or artistic impression? I'd say chucking a load of sand/gravel in the intake might be good for the first, some sort of coolant system sabotage (slash a hose) or fuel/oil contamination for the second, and I'll need more time to think of something interesting for the third
Liam
prawnabie
posted on 19/1/10 at 06:33 PM Reply With Quote
Brake fluid down the inlet!
posted on 19/1/10 at 06:35 PM Reply With Quote
you need to keep an eye on the interior heater going cold! Thats saved me a couple of engines.
zilspeed
posted on 19/1/10 at 06:37 PM Reply With Quote
That is one insane piece of legislation.
And I thought scrappage was nuts.
Actually writing into the legislation that they have to wreck the engine is just bizarre.
posted on 19/1/10 at 06:43 PM Reply With Quote
Give it to a woman and send her to a filling station that has petrol and diesel
(said the very scared man running for cover)
Andi
posted on 19/1/10 at 06:47 PM Reply With Quote
It is all that is wrong and evil compared to LCB website
MakeEverything
posted on 19/1/10 at 06:57 PM Reply With Quote
replace the oil with watered down grinding paste and rev it to the max ubtil pop.
Feed the inlet with propane, and replace the fuel with alcohol.
Kindest Regards,
Richard.
ashg
posted on 19/1/10 at 07:06 PM Reply With Quote
here is the sad side of it
Link
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
iank
posted on 19/1/10 at 07:09 PM Reply With Quote
The big car companies wrote the legislation (via their bought congressmen and lobby groups). Makes a lot of sense for them.
Anonymous
tomgregory2000
posted on 19/1/10 at 07:11 PM Reply With Quote
If you do this when the engine is running its great for de cokeing(sp) the bore
scudderfish
posted on 19/1/10 at 07:25 PM Reply With Quote
How about a load of polystyrene beads down the inlet? Most would burn, but it'd make a very sticky mess inside.
sebastiaan
posted on 19/1/10 at 07:33 PM Reply With Quote
I'd say it is a good thing getting rid of those (mostly american V8 gas guzzling....) monstrosities.
Even if you belong to those who oppose the theory that we as humans are causing global warming, you must agree that we are using up oil at an alarming rate and that the oil that is still there is in increasingly unfriendly places.
Middle-East, anyone?...
Ninehigh
posted on 19/1/10 at 07:36 PM Reply With Quote
Trying to remember what Mythbusters did... I think it was bleach in the oil, still ran though (like a sack of s**t)
If you want something quick swap the petrol/diesel and for artistic make the throttle cable a little sticky
Steve G
posted on 19/1/10 at 07:40 PM Reply With Quote
Drive off and BOOM
I like that plan....... but can we substitute "engine bay" for "Pikey caravan"??
Am i allowed to say that??
tomgregory2000
posted on 19/1/10 at 07:57 PM Reply With Quote
Drive off and BOOM
Yes but only if there is a "pikey" inside or lots
<<  1    2  >>
