tomprescott
| posted on 21/1/10 at 11:14 AM |
Top Wishbones
Hi Everyone,
Seeing the other top wishbone thread reminded me that I still need to make mine
My chassis is as per the ron champion book, but I'm going to be using sierra hubs with an adapter mushroom. I know that the book dimensions for
the top wishbone's are wrong, don't suppose someone could tell me what they are?
Tom
James
| posted on 21/1/10 at 12:46 PM |
You want a minimum of 22mm castor instead of 11mm as per the book.
But they also need to be a bit longer because you're using Sierra instead of Cortina. Approximately 1 or 2" longer I'd have
guessed.
James
- Muhammad Ali
tomprescott
| posted on 21/1/10 at 02:46 PM |
Ok, thats a start, cheers.
Should I use the haynes roadster setup for the top or are they completeley different?
Just thinking that 1 or 2 inches difference in length is going to make a huge difference in handling, I really want to get these perfect!
blakep82
| posted on 21/1/10 at 04:02 PM |
guessed.
James
don't the top wishbones have to be shorter for sierra?
never given it much thought as i used bedford midi uprights, but i thought the sieera ones had the top balljoint a lot further in compared to the
cortina one?
________________________
tomprescott
| posted on 21/1/10 at 04:18 PM |
Oh no, conflicting advice!
Is it wosher that makes wishbones? Perhaps I should give him a bell?
James
| posted on 21/1/10 at 04:37 PM |
guessed.
James
cortina one?
Looking at the 2nd pic here:
http://www.locostbuilders.co.uk/viewthread.php?tid=128643
I've have said the wishbone needs to be longer with Sierra.
This pic:
http://www.pistonenvy.com/westfieldpics/build/main/fntsus1.jpg
of Cortina would seem to agree as well.
James
[Edited on 21/1/10 by James]
- Muhammad Ali
