Author: Subject: BEC chain driven transfer / diff / reverse
aitch
posted on 23/1/10 at 12:19 PM Reply With Quote
has anyone fitted or has experience of one of these in a BEC
shown here on a hayabusa trike the diff / transfer box is chain driven with a 1/1 ratio i believe the final drive ratio is built into this unit as a reverse gear
seems it might solve a lot of the issues with chain drive
posted on 23/1/10 at 12:34 PM Reply With Quote
Look to me like the rear of a Quaife / Poweretec box from the Radicals.
If so, then it is great... if you have three and a half grand going spare
It's Evolution Baby!
posted on 23/1/10 at 12:36 PM Reply With Quote
... and it involves some fairly expensive mods around the engine-drive are.
aitch
posted on 23/1/10 at 01:11 PM Reply With Quote
had to ask
that idea out of the window then way too far from locost
aitch
posted on 23/1/10 at 01:34 PM Reply With Quote
Indeed... it's the perfect solution Aitch, but bloody expensive!
aitch
posted on 23/1/10 at 02:01 PM Reply With Quote
back to a modified sierra lsd and startor motor reverse
of course this has the advantahe of easily being able to change sprockets and therefore final drive ratios
aitch
StevieB
posted on 23/1/10 at 03:05 PM Reply With Quote
IIRC some people have used a starter chain and sprocket on one side of the diff and a starter motor/sprocket on the other side for reverse. Might make life a little tricky if planning inboard brakes but apart from that should work.
I know someone on here has done it, just can't think who...
posted on 23/1/10 at 03:19 PM Reply With Quote
Just out of interest, do trikes need IVA?
StevieB
posted on 23/1/10 at 03:21 PM Reply With Quote
They go through Motorcycle SVA, which is a lot easier than IVA.
posted on 23/1/10 at 03:27 PM Reply With Quote
Ta!
