Author: Subject: Type 9 reverse switch
cd.thomson
posted on 26/1/10 at 12:01 PM Reply With Quote
I don't think my t9 has a reverse switch fitted. Could someone point me in the direction of where it should be?
On a side note I'm probably after one along with a handbrake switch and the sierra horn switch (fitted in conjunction with the copper ring- not needed) if anyone has them lying about!
Craig
flak monkey
posted on 26/1/10 at 12:02 PM Reply With Quote
You can see mine in this pic. Next to the p clip on the cable
You can have the one thats in there as well if you need one. I have no need for it.
Gearbox fitted 1
Gearbox fitted 1
[Edited on 26/1/10 by flak monkey]
Sera
http://www.motosera.com
cd.thomson
posted on 26/1/10 at 12:06 PM Reply With Quote
That would be ace David, do you not use reverse?! I will u2u you later once i've double checked but I'm sure I only have a cable speed drive on that side, no terminals. I guess it's a screw in jobby.
Craig
blakep82
posted on 26/1/10 at 12:09 PM Reply With Quote
the switch is only for reverse lights! it doesn't actually select reverse!
________________________
cd.thomson
posted on 26/1/10 at 12:12 PM Reply With Quote
Haha yes I know! But for MOT and all that, don't you need a working reverse light?
Craig
flak monkey
posted on 26/1/10 at 12:16 PM Reply With Quote
Nope, no legal requirement for a reversing light.
Sera
big-vee-twin
posted on 26/1/10 at 12:23 PM Reply With Quote
Need a reversing light to pass IVA however
http://www.triangleltd.com
blakep82
posted on 26/1/10 at 12:30 PM Reply With Quote
^ yep. silly isn't it?
need one for IVA, didn't need one for sva, and don't need one for MOT
tomgregory2000
posted on 26/1/10 at 07:44 PM Reply With Quote
BUT if a reversing lamp is fitted it MUST be working for mot
loggyboy
posted on 4/4/12 at 11:09 AM Reply With Quote
I know its digging up an old thread, but just to say in case anyone is using this thread as reference, thats not true, the reverse light is not checked at MoT, fitted or not.
snowy2
posted on 4/4/12 at 04:07 PM Reply With Quote
Don't need heater or demisters for MOT but you do for IVA. lots of random things like that
new euro requirement for tyre pressure sensors apparently wonder if it will be added to IVA. (Unless its april fool)
sometimes you are the pigeon, most of the time the statue.
