Author: Subject: EDIS coil pack capacitors
scudderfish
posted on 29/1/10 at 11:38 AM Reply With Quote
Apparently, there should be a suppression capacitor on the plugs that go into my coil packs. However I don't have them. Ebay turns up nothing, does anyone know of an online supplier?
Regards,
Dave
mcerd1
posted on 29/1/10 at 11:46 AM Reply With Quote
scrapyard ?
its this bit I think:
often on the side of the coilpack mounting - sould only cost a few pence (assuming it doesn't just end up in your pocket )
[Edited on 29/1/10 by mcerd1]
cd.thomson
posted on 29/1/10 at 11:54 AM Reply With Quote
wtf is that, i dont have one
Craig
r1_pete
posted on 29/1/10 at 11:57 AM Reply With Quote
I never used one either, its only an interference supressor.
I binned one only last weekend, if its still in the garage bin I'll let you know...
scudderfish
posted on 29/1/10 at 01:22 PM Reply With Quote
Thanks for the offer, although I'll need to track down a second one as I have a V8 and I'm running 2 packs
posted on 29/1/10 at 02:07 PM Reply With Quote
Standard stuff on zetecs, although NOT ALL! I check under the bonnet of Fords when I'm in the srappy for sensors and wiring and very rarely see one.
No idea what made Ford put them on some and not others.
Heres mine mounted on the coil pack bracket as intended. Rescued attachment Suppressor.jpg
big_wasa
posted on 29/1/10 at 05:33 PM Reply With Quote
from memory its about 20 micro farrads
posted on 29/1/10 at 06:26 PM Reply With Quote
25 micro farrods
paulf
posted on 30/1/10 at 08:02 PM Reply With Quote
I fitted one after running without for a couple of years but didn't notice any difference.
Paul.
