Author: Subject: Diff Dilema
Nosbod
posted on 3/2/10 at 09:44 PM Reply With Quote
Diff Dilema
In my R1 Indy i'm currently running a 3.92 sierra diff with push in shafts and standard drum brakes.
I am looking to change the diff and have sourced 2 different options.
1) a 3.62 which will simply replace the 3.92 i have.
2) a 3.36 from a Granada with bolt on shafts, discs etc.
Which would be the better option and will the hassle/cost of fitting the 3.36 give worthwhile benefits over the simple drop-in of the 3.62?
Thanks in advance,
Chris.
austin man
posted on 3/2/10 at 09:47 PM Reply With Quote
Arent the Granada items slightly bigger diffs ??
daniel mason
posted on 3/2/10 at 10:00 PM Reply With Quote
think they are 7 1/2" from granada but there is a 3.38 7"diff i think!
some 3.62 difs have LSD
posted on 3/2/10 at 10:03 PM Reply With Quote
I've just changed the diff in mine, replaced the 3.62 for a 3.92 and its made the car more lively on the road, better take up and now I can doughnut as well
I have a 3.62 with push in shafts here if you need them...
daniel mason
posted on 3/2/10 at 10:17 PM Reply With Quote
my R1 mnr has 3.62 lsd and hits 123 mph! the 3.38 will oviously hit a higher speed but it might not be quite as lively through the gears. i personally think the 3.62 is best for this engine but others will disagree
Mr G
posted on 3/2/10 at 10:58 PM Reply With Quote
If the 3.38 is non lsd then there is the option of taking the back plate off and removing the circlips that hold the lobro stub flanges on allowing you to take them off and use push in shafts.
posted on 4/2/10 at 08:45 PM Reply With Quote
Stick the 3.62 diff in. The ratio of the Granada diff may be slightly better but not worth the hassle of changing the diff mounts to accomodate it.
Phil
Nosbod
posted on 5/2/10 at 07:31 PM Reply With Quote
Thanks to everyone for your help.
I am going to buy both, and initially drop the 3.62 in. If i'm happy with it then all is well, if not at least i'll have the option of swapping over to the 3.36.
