Author: Subject: Diff Modification.
Nosbod
posted on 10/2/10 at 02:23 PM Reply With Quote
Diff Modification.
Is it possible/feasible to convert a diff with bolt on type shafts to use push in shafts?
I was hoping it might be as simple as removing the flanged output stub (shown in picture) to allow push in shafts to be used.
Chris.
336_Diff
336_Diff
[Edited on 10/2/10 by Nosbod]
cd.thomson
posted on 10/2/10 at 02:24 PM Reply With Quote
yep
Craig
ashg
posted on 10/2/10 at 02:26 PM Reply With Quote
just remove the back cover of the diff then remove the clips holding them in.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
minitici
posted on 10/2/10 at 02:30 PM Reply With Quote
Assuming that it is not an LSD....
The LSD uses a longer splined left hand output shaft.
mcerd1
posted on 10/2/10 at 02:38 PM Reply With Quote
and you've got the right sizes push-in shafts
Nosbod
posted on 10/2/10 at 03:06 PM Reply With Quote
Thanks for the quick responses.
Both diff's are non-lsd so it's looking promising.
However, when you say about different size shafts do you mean diameter (i,e. spline etc) or length (or both).
Chris.
RAYLEE29
posted on 10/2/10 at 04:20 PM Reply With Quote
I love the way it all sounds so easy
remove cover reasonable if the bolts come undone
take off circlips hmmmmm sounds really easy lol good luck
rest is easy though
Ray
Dusty
posted on 10/2/10 at 11:49 PM Reply With Quote
Wack each bolt head twice with a 2lb hammer before trying to undo. Works like a charm.
