smac
posted on 11/2/10 at 10:20 PM |
Zetec / MT75 Starter
I know this is a subject thats been done to death and I have tried searching but to no avail -
Im swapping my pinto/MT75 for a Blacktop Zetec/MT 75. At the moment im just trial fitting the engine and box to get the position right so Im using
the same starter motor which may or may not mate with the flywheel when its on. However because I can mount the engine and hence box lower with the
zetec the solenoid on the side of the starter fouls the chassis rail whereas before it sat above it. Do all starters have the solenoid in the same
position? Have other zetec users solved this problem?
big_wasa
posted on 12/2/10 at 01:25 PM |
mines zetec/mt75 I ended up adjusting the chassis to fit the starter.
smac
posted on 12/2/10 at 04:59 PM |
How did you adjust the chassis? Cut the leg?
