<<  1    2  >>
Author: Subject: Garage Clearout - NOW WITH PICS
Krismc
posted on 12/2/10 at 08:24 PM Reply With Quote
Cant realy afford to finish my MNR so im selling everything in the garage that i dont need or isnt nailed down so ill be adding to this list 2mora and adding pics as soon as i can, most stuff is new or used and not that worn. can be picked up or sent from gateshead, or i can drop off just ask, cheers kris
New :- Bullet camera Kit cost £250 Accept £100 - SOLD TO REMAN
New :- multi camera roll bar mounts x2 - heavy duty cost £60 accept £25 -SOLD
New :- Neuros MP4 Recorder £100 accept £35 -SOLD TO REMAN
New :- Mini Rear Light lenses both rear ones - full set with top and bottom lenses side parts and chrome fittings and bulb holders and wires etc all brand new - cost £55 will except £30
New :- Square Reverse Light Cost £6 Accept £2.50
New :- V shape alternator pully with key way - £2.50
New :- RS Red push button (start button) 356-1845 cost £20 - accept £8 -SOLD TO LOTUS MAD ANDY
New :- Bike mirrors and plates IVA friendly Style and make to confirm - one lense smashed other wise new and unused - cost £50 - accept £25 for the pair
New :- Sender Unit adapter M1481.5 to 1/8NPt £3
- SOLD TO BIG WASA
New :- Burton Bleed hose kit for brakes/clutch APC8 £5
New :- Zetec engine stainless kit for center of cam cover to cover leads £5 - SOLD TO DODDY
New :- Halfords alternator belt 900 mm Multi v £2.50
New :- Halfords alternator Belt 813 mm mulit v £2.50
New Chrome Gear gator surround - £8
Used :- handbrake gator surround metal finished with primer and holes predrilled -£6
Used :- Ford handbrake cable - cut in half -now not required has been fitted for 1 year but car never moved from garage -hence looks newish £10
Used :- Gear Gator and plastic surround £5
Used :- Home made Gear Gator leatherette £2.50 - could do with a wash
Used :- Fan Switch £2.50
Used :- fog light switch £2.50
ight switch £2.50
Used :- AirTemp Sensor £3.50
Used :- Ford inlet rubbers x4 with clips x8 £10 - SOLD TO MIKE R
Used :- 4 ram pipes to fit on bike throttle boddies have been trimmed so they fit boddies need tiding cost £40 accept £15
Used :- 2 x water proof Plastic Storage sheds aprox 1 meter high 2 1/2ft wide tool holes/clips and 2 shelves in each- i had them fixed to wall in garage for 2 years they are in very good condition COST £60 each ACCEPT £15 each
Used :- 4 Shelving units from Machine mart, same as these but worn and been fitted 3 years ... http://www.machinemart.co.uk/shop/product/details/csr5350bp-350kg-boltless-shelving-blue/path/tool-racks-shelving-workshop-flooring ..
cost £55 quid each - Accept £20 each NOW ONLY 1 1/2 LEFT ACCEPT £20 FOR THE LOT THATS 12 uprights 1 meter tall, 14 x cross beams long, 14 cross beams short and 7 SHELVES can be used as 3 benchs
Brand New :- Blue Next Gps- portable GPS- cost £27 last week t £12.50 - SOLD TO MIKE R-
Used- Large Blue unbreakable plastic crate brilliant for electolysis, parts cleaning or parts storage £10
Used :- Wall mountable tool tray B&Q type cost £15 - accept £4
used :- Clark pneumatic rotary orbital sander plus a few mounts (see machine mart - Clarke 6" Heavy Duty Dual Action Sander - CAT24B) for details cost £35 accept £15
Clarke used spray gun - cost £23 accpept £10
Clarke Used mastic sprayer used once to spray under seal to my mini- £5
short Lenght of 4 inch flexible air ram pipe - £5 (approx 18inches) - Coozer got first dibs
Battery powered overhead hoist with electric traverse motor will lift and move approx 200kg and 2 lenghts of 2 meter track and charging station, hand control, emergency lowering etc and ill throw in a few new batterys just in case- lifts a 2000cc zetec no bother. Cost £3000 yes £3000 will accept £75
New :- Ford Zetec Oil Filter Cost £5.60 Accept £2.50 - SOLD TO DODDY
New :- 2 x 50mm exhaust clamps - £2 both
New :- Aero nylon fuel restrictor to meet IVA Cost a unbelivable £8 accept £2.50 - SOLD TO BIG WASA
Used - SDS 110V BOSCH hammer drill £cost lots and lots £25- pick up only
GSXR 750 K5 Throttle boddies.
Come with TPS , Fuel rail and injectors and linkage, Perfect for a throttle body convertion as you can split the throttle bodies into individuals and space them according to the inlet spacing of your engine and enjoy the noise these are the most common TB's used as they offer great scope for power and response, 48mm outlet tappering to a 42mm inlet.
£100 ono
Rotating engine stand - machine mart one like this ...
cost £80 accept £30 its got a bit of surface rust as my mate decided to leave it out side for 2 weeks - SOLD TO LOTUS MAD ANDY
[Edited on 14/2/10 by Krismc]
doddy
posted on 12/2/10 at 08:29 PM Reply With Quote
i will take the zetec cam cover
oil filter plus have you a picture of the chrome gear surround
[Edited on 12/2/10 by doddy]
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 12/2/10 at 08:38 PM Reply With Quote
U2u'd re camera.
Krismc
posted on 12/2/10 at 09:14 PM Reply With Quote
Both replied too and list updated
MikeR
posted on 12/2/10 at 09:22 PM Reply With Quote
I'll take the GPS unit and ford rubbers if the postage is reasonable - can you u2u me how much you think it will cost?
eddie99
posted on 12/2/10 at 09:36 PM Reply With Quote
U2U sent about gaitors
Xtreme Kermit
posted on 12/2/10 at 09:40 PM Reply With Quote
U2U sent re multi camera roll bar mounts x2
big_wasa
posted on 12/2/10 at 10:27 PM Reply With Quote
I will have the fuel cap reducer and the the 1/8npt adapter please.
Dangle_kt
posted on 12/2/10 at 11:07 PM Reply With Quote
Hi Kris,
Sorry for the hijack but did you ever sort the emissions on your car for IVA?
Last I heard was your SVA disaster.
MakeEverything
posted on 12/2/10 at 11:34 PM Reply With Quote
U2U RE: Shelving.
Kindest Regards,
Richard.
Krismc
posted on 13/2/10 at 09:00 AM Reply With Quote
All U2Us Replied and list updated.
ReMan
posted on 13/2/10 at 12:16 PM Reply With Quote
I'll take the camera and recorder unit....
u2u too
Krismc
posted on 13/2/10 at 05:49 PM Reply With Quote
ALL 13 U2US replied too.
Please reply u2us with the full content as i cant remember what people asked for- dont make me make a list- i hate lists
Krismc
posted on 13/2/10 at 06:05 PM Reply With Quote
5 New items added - still downloading and uploading photos
Krismc
posted on 14/2/10 at 09:12 AM Reply With Quote
New Photos added.
Going in garage today cause i got a day off (makes a change) and and sort some more nice goodies out
Krismc
posted on 14/2/10 at 09:51 AM Reply With Quote
......Set of GSXR 750 K5 Throttle boddies- added to list.
Comes with TPS , Fuel rail and injectors and linkage
Perfect for a throttle body convertion as you can split the throttle bodies into individuals and space them according to the inlet spacing of your enjoy.
As pictured on my car below.... i will throw in the trumpets if they havent sold.
Krismc
posted on 14/2/10 at 10:30 AM Reply With Quote
I need a DIFF if anyone has a spare lying round - swap for something above.
Krismc
posted on 14/2/10 at 10:38 AM Reply With Quote
Item added - engine stand.
lotusmadandy
posted on 14/2/10 at 12:19 PM Reply With Quote
u2u,d regarding the engine stand and starter button.
Krismc
posted on 14/2/10 at 01:33 PM Reply With Quote
Cheers Andy- SOLD
OH i measure and Roughly ram pipes are 51mm external 48.5mm internal and 70mm long just incase anyone needs too know
Krismc
posted on 14/2/10 at 01:38 PM Reply With Quote
V pully is brand new 15mm internal, and is 65 x 20mm overall.
Ram pipe is more like 18inchs, ill have to measure properly
x-generator
posted on 14/2/10 at 07:18 PM Reply With Quote
Interested in the throttle bodies - where are you based?
Krismc
posted on 14/2/10 at 08:26 PM Reply With Quote
In newcastle, TBs are currently in harrogate @MNR though.
but can get them for you.
Krismc
posted on 15/2/10 at 04:51 PM Reply With Quote
Still Plenty of stuff left
Tre7or
posted on 15/2/10 at 05:22 PM Reply With Quote
Ram Pipes x 4
I will take the ram pipes please
Tre7or
<<  1    2  >>
