Author: Subject: Scoop Suggestions
FrankP
posted on 13/2/10 at 05:36 PM Reply With Quote
Scoop Suggestions
I have cut a hole in my bonnet - I now need a scoop to cover the inlet manifold any suggestions.
I also need an air filter suggestions also welcome.
thanks
tegwin
posted on 13/2/10 at 05:59 PM Reply With Quote
Do you really want a scoop?
I would have thought a bulge would look much nicer...
Either way... you could make one yourself using insulation foam as a mold....
That way it would fit perfectly... much better IMHO than bolting on something generic
Wont take long to make a bulge from fibreglass
Edit to say... do you not have an airfilter/induction pipework to go on there too?
[Edited on 13/2/10 by tegwin]
www.verticalhorizonsmedia.tv
mookaloid
posted on 13/2/10 at 06:04 PM Reply With Quote
Beat one out of ally sheet. I don't think you'll get one off the shelf to fit that on the curve of the bonnet.
Or fit a different inlet manifold and air filter which won't stick up - then patch or replace the bonnet.
big_wasa
posted on 13/2/10 at 06:33 PM Reply With Quote
trim it up a bit neater and polish or paint the inlet.
display it , it may look better ?
tegwin
posted on 13/2/10 at 06:48 PM Reply With Quote
Good call... Paint it black and do the letters in gold!
Guihanos
posted on 16/2/10 at 09:04 AM Reply With Quote
it's not finish yet but I've done that on mine. You will have to make it bigger to fit yours. I used a kitchen plate as a mould to make it. And then cut it in the good dimension.
