Author: Subject: A4 1.8T running like dog
StevenB
posted on 16/2/10 at 01:40 PM Reply With Quote
Climbed into A4 this morning and it was like a 1L fiesta.
No power at all.
Any suggestions that do NOT include the
bloody quote for £550 for a new turbo
i've just got.
s
oadamo
posted on 16/2/10 at 01:45 PM Reply With Quote
any fault codes, check the plugs first.pop the pipe off for the turbo and have a feel to see how much play is in the shaft aswell.
adam
[Edited on 16/2/10 by oadamo]
Dan.
posted on 16/2/10 at 01:46 PM Reply With Quote
check all hoses, there is a good chance its just a boost hose. Had the same issue with my 306 and it was just a small boost hose causing the problem. good luck
D Beddows
Vacuum hose/s split blown off? .... different car I know but I had a similar thing with my Saab and new silicone vacuum hoses (about £5 to replace the whole lot ) transformed it. I have had just one go previously mind you and the car went like a 1.6 Nissan Bluebird
[Edited on 16/2/10 by D Beddows]
hobbsy
posted on 16/2/10 at 01:49 PM Reply With Quote
Don't the AFM/MAF's play up on these?
Try disconnecting it to see if it makes a difference?
Its not in a limp home mode is it?
There is also an electronic boost control valve which might be playing up (and meaning you get little or no boost)
And as mentioned an air leak will kill the performance (but you can often hear it)
Normally if the turbo is knackered you'll get other clues like smoke or whistling etc.
Danozeman
posted on 16/2/10 at 02:23 PM Reply With Quote
n75 boost valve? AFM? boost pipe popped off? Boost sensor?
Get it plugged in if you can theres so much it can be.
Dan
jos
posted on 16/2/10 at 07:17 PM Reply With Quote
Try to get it on VAGCOM to look for faults
Could be coil packs - easy replace when you know from VAGCOM which one(s) are causing problems.
Also on the top of the engine there might be a breather hose from the top of the cam cover. This had split on mine causing rough running - dodgy signals to the ECU
Lastly the throttle body could need cleaning
t.j.
posted on 16/2/10 at 08:00 PM Reply With Quote
new turbo....inlet....
So hoses are been detached....
So look for bad mounted hoses...
Mark Allanson
posted on 16/2/10 at 08:09 PM Reply With Quote
Take out the LH archliner, the intercooler hose clips are very weak and pop off with amazing regularity. We get it all the time - we reassemble a car after a front end replacement, the owner has the car back and 3 days later they complain that the car is running badly.
As an eternal optimist, this one may cost you as much as £3.70!
StevenB
posted on 16/2/10 at 08:17 PM Reply With Quote
Thanks for the advice.
Forgot to say this is a 1997 model.
All bit and pieces appear to be attached OK.
Changing air filter and plugs as we speak.
Dont know if it will help but probably needed done anyway.
s
RK
posted on 17/2/10 at 12:37 AM Reply With Quote
coil packs are a known issue on 2001 and onwards, so may be that on your earlier one too.
StevenB
posted on 3/3/10 at 01:30 PM Reply With Quote
Update :
Car hooked up to computer.
Logged 3 faults.
N75
AFM
and
Crank position sensor.
The N75 was reading zero volts
on application of accelerator.
New N75 valve has cleared down
the 3 faults above but car is still running as slow as ever.
Computer is now reporting Cam position sensor fault (open to positive).
The car would happily drift along at 2000rpm in 5th but there is nothing there
when I put the foot down and its a struggle to move off on a hill start.
Anymore thoughts?
Thanks for the comment so far.
S
posted on 3/3/10 at 07:44 PM Reply With Quote
Does it sound like it's misfiring?
StevenB
posted on 5/3/10 at 01:13 PM Reply With Quote
No miss fires.
Runs the slightest bit lumpy on idle but never cuts out.
Would a dud coil pack not create a very uniform sounding miss fire?
Anybody have a comment on possible issue with fuel filter?
s
