Author: Subject: Vdo gauges
dave1888
posted on 27/4/04 at 10:19 PM Reply With Quote
Vdo gauges
Can any vdo gauges be used on 7 type cars eg. vdo gauges from vw/audi
keithchristie
posted on 28/4/04 at 08:12 AM Reply With Quote
Vdo gauges
I looked at oil temp/oil pressure/volt gauges from Audi 80/Golf for my car.
They'll work no problem with the correct senders, although the speedo may be a bit trickier.
I got my full VDO dashboard from here http://www.lowtension.co.uk/ - look under "Instrument Kits | Gauges". They also do VDO senders.
The kit was £290, vs £500 else where.
They were very helpful and even switched the water temp gauge for an oil temp gauge as my engine is oil/air cooled.
If you use an electronic speedo, you can adjust the speed by using one of these http://www.blackrobotics.com/index.htm
or these http://www.speedohealer.com/eng/intro.htm
The VDO speedo I got from Lowtension can be calibrated to suit, so you then wouldn't need the yellowbox etc.
Hope that helps
mad4x4
posted on 20/5/04 at 11:29 AM Reply With Quote
I got the same VDO kit from Low tension and bought a gearbox sender.
The lad at low tesnison is great help . all I'll say is I got a good price.
These kits sometimes come up on eaby thats where I initially spotted lowtension
Scot's do it better in Kilts.
