Author: Subject: Which is best to clean with before painting?
MikeR
posted on 19/2/10 at 03:26 PM Reply With Quote
Ok, should i be wiping down with acetone or cellulose thinners before painting my chassis?
I've handed the chassis a hundred times and probably had wd40 etc sprayed over it occasionally.
Want something that will get rid of the grease / anything else prior to hitting it with the paint.
(fast answer appreciated as I've just ordered acetone and then panicked thinking it should be cellulose thinners - should still be able to change the order (i hope)).
mads
posted on 19/2/10 at 03:28 PM Reply With Quote
i thought you were going to get it powdercoated?
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
MikeR
posted on 19/2/10 at 03:33 PM Reply With Quote
yeah - but i figured i've got a week between jobs and a garage full of tools.
Its got to be easier to wipe, clean (emery cloth / angry grinder), wipe, let dry, paint than stripping the car, organising trailer and tow car, taking it to place, getting them to do it, bringing it back, returning stuff.
aka i'm cheap bottomed person from the higher lattitudes - thats cheap ass northerner to you.
(although i'm still tempted with blasting as i could prob hire a van for a day, get it in, get it done and be back and spend some of my redundancy - just struggle with the spending cash bit & worry about getting a poor job).
blakep82
posted on 19/2/10 at 03:41 PM Reply With Quote
i'd have thought cellulose would be better, but i recon acetone will do a decent job too
edit: but doesn't acetone leave a slight oily film?
[Edited on 19/2/10 by blakep82]
________________________
speedyxjs
posted on 19/2/10 at 03:51 PM Reply With Quote
I rubbed mine down with wet and dry (all i had ), wiped over with white spirit and painted with hammerite (by hand so as not to waste paint)
r1_pete
posted on 19/2/10 at 03:53 PM Reply With Quote
Either will be fine, but use paper towels first and keep chucking them away, that way you dont just spread the oil all over in a thin layer.
A final wipe with a thinners damped lint free cloth to get the paper bits off and away you go.
Bluemoon
posted on 19/2/10 at 03:59 PM Reply With Quote
acetone will be o.k... use it to really clean stuff at work (for the space industry). Nasty stuff though, get some good ventalation...
Dan
I seem to recall meths is okay but white spirit has oils in it (or that is what I was told in relation to cleaning the protective film off new brake discs).
Bluemoon
yes
MikeR
posted on 19/2/10 at 04:07 PM Reply With Quote
so acetone is ok - but which out of the two is better?
ie if acetone is ok, but cellulose is better, i'll get the cellulose.
(yes, i'm having a friday panic - 10 years to get this far, i don't want to mess up now!)
MikeR
posted on 19/2/10 at 04:08 PM Reply With Quote
sort of implies that i should just get cellulose thinners then if i've got to use that at the end.
blakep82
posted on 19/2/10 at 04:17 PM Reply With Quote
i bought 5ltrs of cellulose thinners for £8 the other week, so not a major expense
wilkingj
posted on 19/2/10 at 04:20 PM Reply With Quote
What ever you use, take real good care of yourself. ALL of these solvents are nasty!
Please use the proper protective clothing. Decent solvent proof gloves eye shields, and have the place properly ventilated even if you half freeze to death.
These solvents are absorbed by the skin and can attack your nervous system.
It isn't worth injuring yourself through your own neglect.
Believe me... I've been there
[Edited on 19/2/2010 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
boggle
posted on 19/2/10 at 04:47 PM Reply With Quote
go to your local paint supplyers and get a tin of pannell wipe..
u2u me for details
Guihanos
posted on 19/2/10 at 04:53 PM Reply With Quote
Each time I have to paint something I use Wine Vinegar. An old painter told me why it was the best to do but I don't remember. Anyway it always remove the oil and protect the parts until you spray it.
Don't try Alcool vinegar, just wine vinegar. I know it's strange but I will ask this old painter soon to tell me what is the reason.
splitrivet
posted on 19/2/10 at 05:20 PM Reply With Quote
Panel wipe, its specifically made for the job.
Bob
Danozeman
posted on 19/2/10 at 05:38 PM Reply With Quote
panel wipe is good plus its not as bad for you as acetone etc.
As you have ordered the acetone you may aswell use it otherwise youl just have it sitting there for years.
Dan
MikeR
posted on 19/2/10 at 07:30 PM Reply With Quote
Suspect i'll use a combination of acetone pre chassis clean and panel wipe post.
The left over acetone can be used to clean the g/f nails - once i've persuaded her to start wearing nail varnish
(although getting tempted with the 300 quid blast, epoxy 2 part zinc primer, powder coat from the local blasting place BG Perry in coventry. Its hassle to get it to them and not cheap - but it should be a decent long lasting finish).
dhutch
posted on 19/2/10 at 07:41 PM Reply With Quote
Sounds fair enough to me.
- Ive just repainted the rear of my chassis, it was flithy, so i started with a pressure washer and fairy!
But i then used then some marine clean which seamed to work really well.
Daniel
James
posted on 19/2/10 at 07:58 PM Reply With Quote
Did the whole chassis with The Tool (probably pleased the neighbours no end). Then white spirit followed by Cellulose thinners to take off any residue!
James
posted on 19/2/10 at 09:23 PM Reply With Quote
I bought 5 litres of panel wipe from a local car paint supplier - not that expensive. Volatile stuff, so I decant some into a small bottle for day-to-day use.
Steve Hignett
posted on 19/2/10 at 10:18 PM Reply With Quote
You should wipe your panels with Panel Wipe...
You should also pick up a small pack of Tack-Rags whilst your there, they help no end with stuff like cloth and paper bits and don't cost much. (a small pack will last years!)
