<<  1    2  >>
Author: Subject: Small revvy car engines - hypothetical discussion
alistairolsen
posted on 4/3/10 at 12:28 PM Reply With Quote
I'm building cars in my head again!
If one wanted to build a car based on an old, lightweight rwd car with a modern reliable engine, keeping the original light responsive revvy nature of the car but with economy, refinement and reliability(at elast from the engine) what would you choose?
Preferably sub 1500cc to keep to lower tax bands and light weight.
No bike engines!
I considered the fiat FIRE engines in 16v form but they are tall and ultimately seem to struggle over 100bhp.
I then looked at vauxhall's small-block family one engines (familiar territory) and specifically the 1.5 Daewoo unit which is oversquare ( 81.5 bore and 76.5 stroke) and 1498cc. This engine with a reasonable plenum intake and exhaust would make around 120bhp on its original management but being or iron block construction is quite heavy.
What would you use?
My Build Thread
balidey
posted on 4/3/10 at 12:31 PM Reply With Quote
Rover K-series 1.4.
I am planning on using the 1.8, but if you want sub 1.5 for tax reasons, then fit a 1.4 and swap to 1.8 afterwards.
And its small, light, revvy.
iank
posted on 4/3/10 at 12:33 PM Reply With Quote
K series 1.4, they work well in Midgets
Await's the 'they aren't reliable' brigade to turn up in force.
Anonymous
TimC
posted on 4/3/10 at 12:35 PM Reply With Quote
The K-series hs to be the easy option - Caterham actually fitted the 1.4 at one stage. If you were a whiz with bellhousings, what about the Suziki Ignis Sport 1.5 VVT motor?
balidey
posted on 4/3/10 at 12:36 PM Reply With Quote
Some fantastic articles written on the K series highlighting what the REAL problems were and how to overcome them. Trouble is, poo sticks as they say, and now everyone say 'Head gasket' and walks away. Shame really as it is a cracking engine.
balidey
posted on 4/3/10 at 12:38 PM Reply With Quote
Wow, first 3 posts all suggesting the 1.4 K.
And you can pick up a complete car with one in for a handful of notes. Well, maybe not now thanks to Gifted Gordons scrappage fiasco... but there are still plenty about.
alistairolsen
posted on 4/3/10 at 12:39 PM Reply With Quote
How good bad or ugly are they then? Ive heard of the freelander gasket in 1.8s, but I dont know anyone who has had one and not had issues.....
How tuneable is the 1.4 (standard management and small spend)
My Build Thread
flibble
posted on 4/3/10 at 12:46 PM Reply With Quote
I had a very breif drive in a 1.5l honda vtec civic(?) a while ago and that seemed a nice revvy little motor, I know nothing about them though
Edit: Ignore that, just noticed the RWD element in your OP
[Edited on 4-3-10 by flibble]
liam.mccaffrey
posted on 4/3/10 at 12:51 PM Reply With Quote
They are wonderful!
I kept my 216 and will remove the k from that for a future project sometime. great fizzy, eager engine. Gasket went at 78k, repaired it myself and it now has 130k on the clock and sounds fantastic.
My wife has a MGZR 160 with the 1.8 VVT K in it. Very fast, having traction problems so may need a tire upgrade otherwise very strong @ 70k
Plenty of info out there on how to avoid HGF. Easily prevented.
Build Blog
Build Photo Album
alistairolsen
posted on 4/3/10 at 12:54 PM Reply With Quote
link for me to digest later
http://www.aronline.co.uk/index.htm?essaykseriesf.htm
My Build Thread
iank
posted on 4/3/10 at 12:58 PM Reply With Quote
Also worth poking around http://www.dvapower.co.uk/
Anonymous
smart51
posted on 4/3/10 at 01:03 PM Reply With Quote
1.4 K series revs to 6750 and makes 103 PS. 1.8 VVC revs to 7200 and makes 143 PS (there was a higher output version). Lotus VHPD 1.8 uses the vvc head without the vvc and makes 190 BHP. All weigh 99-100kg
D Beddows
posted on 4/3/10 at 01:04 PM Reply With Quote
I'm actually quite a fan of the Vauxhall 16v 1.4 as fitted to Astras etc - Mrs Beddows has one and much to my surprise (not a Vauxhall fan at all tbh) it's actually fun to drive even in an Astra if you keep it revving Plus you can get fairly huge BHP out of it if you spend a bit of money........ but even with just a proper exhaust and intake system it would be a cracking engine!
alistairolsen
posted on 4/3/10 at 01:11 PM Reply With Quote
D Beddows: I know, I have the 1600 version in a nova track car! That was why I went looking as the 1400 is oversquare and the 1500 is better again!
Im actually ashamed to admit id forgotten about the k series even when thinking of small modern revvy alloy engines
My Build Thread
stevec
posted on 4/3/10 at 01:19 PM Reply With Quote
Another one for Kseries.
Very light and reliable if screwed together properly.
Steve.
GRRR
posted on 4/3/10 at 01:26 PM Reply With Quote
On a non-Vauxhall theme, the Suzuki Swift GTi (old shape early 90s) have very nice revy 1300 16v 100bhp standard engines and bolt on to the RWD box from a Suzuki SJ jeep.
Friend of mine had one in a Striker.
alistairolsen
posted on 4/3/10 at 01:31 PM Reply With Quote
What box would one use with the K series?
http://kengine.dvapower.com/
[Edited on 4/3/10 by alistairolsen]
My Build Thread
D Beddows
posted on 4/3/10 at 01:35 PM Reply With Quote
Another 1300 engine I've always liked Nissan Micra 1.3 16v is another but the rwd aspect is an issue....
As you may have guessed I'm quite a fan of little revvy car engines too
[Edited on 4/3/10 by D Beddows]
posted on 4/3/10 at 01:39 PM Reply With Quote
Standard K 1.8 series as used in the R45 R75 and MG ZT 1.8 and Freelander 1.8 only made 118 hp ---- but other versions made up to 160 hp
The 1.6 made about 116hp as standard, and the 1.4 usually made 103hp --- figures varied a bit depending on year.
For insurance reasons the the base model Rover 25 1.4 only made 81hp but only difference from the 104hp version was the butterfly in throttle body was only allowed to open 50% .
Just change the throttle body and throttle cable and get an instant 23hp gain.
posted on 4/3/10 at 01:40 PM Reply With Quote
Type 9 but you need to buy a bellhousing.
iank
posted on 4/3/10 at 01:42 PM Reply With Quote
Type 9 with a bell housing is the normal route.
Caterham did one, as do frontline motorsport (probably others out there as well).
http://www.mgcars.org.uk/frontline/pricelst.htm
Anonymous
iank
posted on 4/3/10 at 01:45 PM Reply With Quote
Originally posted by D Beddows
...Nissan Micra 1.3 16v is another but the rwd aspect is an issue....
Nice engine once you lose the peashooter exhaust, very underrated (though I've no idea if you could fit it on a rwd gearbox).
Anonymous
posted on 4/3/10 at 02:23 PM Reply With Quote
Another vote for K-series and Type 9...
It's Evolution Baby!
D Beddows
posted on 4/3/10 at 02:29 PM Reply With Quote
1275 A series mini engine with a 16v BMW K1100 head is another idea I've always really liked
alistairolsen
posted on 4/3/10 at 02:51 PM Reply With Quote
seen that conversion and while neat I couldnt bring myself to pour that much work into an archaic 3 bearing iron bottom end when there are better engines out there!
My Build Thread
<<  1    2  >>
