Author: Subject: rose joints on solidworks
Miks15
posted on 18/3/10 at 11:24 AM Reply With Quote
Hi guys,
Just a quick one, does anyone know how to make rose joints on solidworks? I need to connect a bell crank to a rocker arm and a simple connector wont do.
Cheers Guys
Jimbob
posted on 18/3/10 at 11:27 AM Reply With Quote
Try 3dcontentcentral.com there are prob some on there for download
Alan B
posted on 18/3/10 at 11:33 AM Reply With Quote
Yes, they are easy actually. I have some modelled in SW 2008.....if don't get what you need by this evening U2U me and I'll send you a model.
Mine are modelled as an assembly with them swivelling around the ball as they should.
Alan
[Edited on 18/3/10 by Alan B]
m8kwr
posted on 18/3/10 at 11:39 AM Reply With Quote
Quite easy to make, if you need one i can send you one i did.
You can also put limits on the movement
Make them in 2 parts, the outer, and inner, then make the assembly, so the parts move (or that is the way i did it)
Miks15
posted on 18/3/10 at 12:40 PM Reply With Quote
u2u sent m8kwr
iti_uk
Builder
Posts 163
Registered 13/10/08
Member Is Offline
Photo Archive Go!
Building: The KLMX-5 ('97 MX5 w/Mazda KL 2.5L V6)
posted on 18/3/10 at 01:05 PM Reply With Quote
If this hasn't already been solved - as mentioned, just model the "ball" and "socket" seperately and then use a point constraint between the two, allowing full rotational freedom. You can set limits relative to the axis of the hole in the ball and the plane parallel to the flats on the "socket".
Sorry, I'm not a Solidworks user, I'm not aware of its capabilities or methods of assembly constraint. If you had Catia I could tell you...
Chris
