Author: Subject: Bugger, overfilled engine
speedyxjs
posted on 23/3/10 at 02:48 PM Reply With Quote
I didnt realise my dipstick tube wasnt fitted properly and have now much too much oil in.
I dont want to undo the drain plug as last time i did that, it came out so fast it overflowed my container and went all over the drive.
Is there any easier way to do it?
iDENTITi
posted on 23/3/10 at 02:49 PM Reply With Quote
Do it the american oil-change way? Big tube, stick it down the dipstick tube, and suck some oil out with a large syringe or similar.
cd.thomson
posted on 23/3/10 at 02:52 PM Reply With Quote
bigger container
Craig
D Beddows
posted on 23/3/10 at 02:54 PM Reply With Quote
Get a bigger container?????????
Edit: too slow - but it is rather obvious
[Edited on 23/3/10 by D Beddows]
stevebubs
posted on 23/3/10 at 02:55 PM Reply With Quote
dough tray from domino's pizza under the car should do the trick....
[Edited on 23/3/10 by stevebubs]
iank
posted on 23/3/10 at 02:59 PM Reply With Quote
linky
or more sensibly
http://www.machinemart.co.uk/shop/product/details/cgg500-500cc-oil-suction-gun
or
http://www.machinemart.co.uk/shop/product/details/14-litre-oil-drain-pan
Anonymous
D Beddows
posted on 23/3/10 at 03:03 PM Reply With Quote
or down the 'household products' aisle at your local Asda - probably £5 at the very most......... or a local £1 shop might be even better Or you could buy a syringe thing you'll probably never use again.....
tomprescott
Pipe down the dipstick tube, either syphon, syringe or if you have (I think its called) a pumpjack then it shouldn't take too long. Good luck
A bird in the hand....
Breaker
posted on 23/3/10 at 03:05 PM Reply With Quote
Put a tube into the dipstick hole, place the other side of the tube below the sump, suck on the tube and let physics finish the job!
posted on 23/3/10 at 03:12 PM Reply With Quote
Buy a Xflow. doesn't matter how much oil you put in once of those suckers, it'll still be empty after a half hour drive
Stott
posted on 23/3/10 at 03:14 PM Reply With Quote
These make brilliant drip trays for future reference, used them all the time when I was in the stealers, but that was land rover, there was a lot of oil dripping......lol
LINK
stuart_g
posted on 23/3/10 at 03:20 PM Reply With Quote
long drinking straw and suck very hard
speedyxjs
posted on 23/3/10 at 03:21 PM Reply With Quote
Love the blow up bath idea
the container i have is only 6 litres and i couldnt find anything bigger. What a great resource locostbuilders is for even the most stupid questions
Cheers guys
iank
posted on 23/3/10 at 03:23 PM Reply With Quote
Originally posted by D Beddows
... Or you could buy a syringe thing you'll probably never use again.....
Until it's time to change gearbox/diff oil
[Edited on 23/3/10 by iank]
Anonymous
afj
posted on 23/3/10 at 03:29 PM Reply With Quote
good call thats what i use great for sevens only 4 inches high but 3 foot square
eerrrrrrrrrrrrrrrr
D Beddows
posted on 23/3/10 at 03:36 PM Reply With Quote
True............. lol, I look forward to meeting you one day Mr ianK
Daddylonglegs
posted on 23/3/10 at 03:52 PM Reply With Quote
LINK
Oooh, like that idea. I've had one of those sitting around for yonks ever since I built my breeze block shed and now I've got a use for it
boggle
posted on 23/3/10 at 04:29 PM Reply With Quote
looks like you need someone with a good suck on them....
u2u me for details
kipper
posted on 23/3/10 at 04:35 PM Reply With Quote
overfill
Do what I did, use a bike pump.
I just cut the end of the rubber conection and poked it down the dipstick hole, draw the pump back and suck out the oil.
(Lots of scope for inuendo there)
Denis.
Where did that go?
Canada EH!
posted on 23/3/10 at 05:58 PM Reply With Quote
Do they sell those small suction pumps that are powered by a hand drill over there, quite cheap here. Tube down the dipstick hole, pump into a container and use for top-ups.
speedyxjs
posted on 23/3/10 at 06:58 PM Reply With Quote
All sorted. Went to the supermarket and found a decent size tray, drained a bit out and now the level is normal.
Taking the prop to be shortened tomorrow so hopefully first drive at the weekend
boggle
posted on 23/3/10 at 07:19 PM Reply With Quote
have you got your bodywork sorted??
u2u me for details
speedyxjs
posted on 23/3/10 at 08:27 PM Reply With Quote
Dangle_kt is kindly sending me some wings to cut'n shut and tomprescott is equally as kindly getting some piccys of his nosecone that he would send to me to modify
boggle
posted on 23/3/10 at 08:29 PM Reply With Quote
thats brilliant.....shes going to be a monster
u2u me for details
johnggill
posted on 24/3/10 at 06:28 PM Reply With Quote
Been wondering how to do diff also dry sump tank which I always overfill. Bought syringe thing off eBay helpful topic.
